Fujifilm FinePix S4200 LCD Screen Replacement
    1. Fujifilm FinePix S4200 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Turn the camera off.
      • Turn the camera upside down so that the battery compartment is showing.
      Ask FixBot
    2. Fujifilm FinePix S4200 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
      Ask FixBot
    3. Fujifilm FinePix S4200 LCD Screen Replacement: step 3, image 1 of 1
      • Rotate camera to the side where the speaker ports are located.
      • Remove the three 4 mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    4. Fujifilm FinePix S4200 LCD Screen Replacement: step 4, image 1 of 1
      • Turn the camera to the opposite side where the HDMI port is located.
      • Remove all five 4 mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    5. Fujifilm FinePix S4200 LCD Screen Replacement: step 5, image 1 of 3 Fujifilm FinePix S4200 LCD Screen Replacement: step 5, image 2 of 3 Fujifilm FinePix S4200 LCD Screen Replacement: step 5, image 3 of 3
      • Casing is fragile.
      • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
      • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
      Ask FixBot
    6. Fujifilm FinePix S4200 LCD Screen Replacement: step 6, image 1 of 1
      • Use force to pull apart the back casing from the camera.
      Ask FixBot
    7. Fujifilm FinePix S4200 LCD Screen Replacement: step 7, image 1 of 1
      • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
      Ask FixBot
    8. Fujifilm FinePix S4200 LCD Screen Replacement: step 8, image 1 of 2 Fujifilm FinePix S4200 LCD Screen Replacement: step 8, image 2 of 2
      • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
      • Flip over LCD screen so that the left side of the metal plate is visible.
      Ask FixBot
    9. Fujifilm FinePix S4200 LCD Screen Replacement: step 9, image 1 of 1
      • Rotate the camera vertically so that it is easier to manage.
      • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
      Ask FixBot
    10. Fujifilm FinePix S4200 LCD Screen Replacement: step 10, image 1 of 1
      • Detach the metal plate from the motherboard.
      Ask FixBot
    11. Fujifilm FinePix S4200 LCD Screen Replacement: step 11, image 1 of 2 Fujifilm FinePix S4200 LCD Screen Replacement: step 11, image 2 of 2
      • The orange ribbon cable is fragile.
      • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
      • Gently remove the LCD screen from the motherboard.
      Ask FixBot
3 other people completed this guide.
Jackie Acevedo
352 Reputation
2 Guides authored
CSU Fullerton, Team 1-4, Bruce Fall 2015 Member of CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Members
16 Guides authored
1 Guide Comment
Ou peut on trouver cet écran ?
lise.didion - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 38
All Time: 2,130
