Fujifilm FinePix S1 LCD Screen Replacement
    1. Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
      • Remove the 4 screws surrounding the LCD screen.
      Ask FixBot
    2. Fujifilm FinePix S1 LCD Screen Replacement: step 2, image 1 of 1
      • Use an opening tool to remove the casing on the hinge of the LCD screen.
      Ask FixBot
    3. Fujifilm FinePix S1 LCD Screen Replacement: step 3, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 3, image 2 of 2
      • Use an opening tool to pry apart the LCD screen casing and remove the casing.
      Ask FixBot
    4. Fujifilm FinePix S1 LCD Screen Replacement: step 4, image 1 of 1
      • Remove the 2 screws located on the inner corners of the inside of the LCD screen.
      Ask FixBot
    5. Fujifilm FinePix S1 LCD Screen Replacement: step 5, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 5, image 2 of 2
      • Disconnect the blue cable set by carefully prying it off with a spudger.
      Ask FixBot
    6. Fujifilm FinePix S1 LCD Screen Replacement: step 6, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 6, image 2 of 2
      • Use a spudger to lift the LCD screen out of its placement and remove it from the casing.
      Ask FixBot
Brandon Benavente
704 Reputation
6 Guides authored
USF Tampa, Team 3-6, Sullivan Spring 2016 Member of USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Members
42 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,251
