Fujifilm FinePix S1 EVF/LCD Button Replacement
    1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: step 1, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: step 1, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: step 1, image 3 of 3
      • Remove the 7 screws on the perimeter of the camera body.
      Ask FixBot
    2. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 2, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 2, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 2, image 3 of 3
      • Remove the flash accessory cap.
      • Remove the spacer covering the screws under the flash accessory cap.
      Ask FixBot
    3. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 3, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 3, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 3, image 3 of 3
      • Remove the 4 screws from the inside of the flash accessory slot.
      • Pull off the flash accessory slot.
      Ask FixBot
    4. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 4, image 1 of 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 4, image 2 of 2
      • Remove the screw from LCD Screen hinge cover.
      • Remove the LCD Screen hinge cover.
      Ask FixBot
    5. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 5, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 5, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 5, image 3 of 3
      • Remove the 3 screws located on the LCD screen hinge.
      • Remove the caps from both ends of the LCD screen hinge by lifting them off.
      Ask FixBot
    6. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 6, image 1 of 1
      • Remove the 2 screws from under the LCD hinge caps.
      Ask FixBot
    7. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 7, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 7, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 7, image 3 of 3
      • Pry apart the back body from the rest of the camera.
      Ask FixBot
    8. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 8, image 1 of 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 8, image 2 of 2
      • Carefully pull the back body off of the camera.
      • Make sure to not yank off the connections from the body to the motherboard.
      Ask FixBot
    9. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 9, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 9, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 9, image 3 of 3
      • Use a spudger to lift up on the tab, releasing the yellow wire strip.
      • Use a spudger to lift up on the side tab, releasing the blue wire connection.
      Ask FixBot
    1. Fujifilm FinePix S1 EVF/LCD Button Replacement, EVF/LCD Button Cover: step 10, image 1 of 1
      • Remove 2 screws from back of EVF/LCD button.
      Ask FixBot
    2. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 11, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 11, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 11, image 3 of 3
      • Pull EVF/LCD button frame out from the camera casing.
      Ask FixBot
    3. Fujifilm FinePix S1 EVF/LCD Button Replacement: step 12, image 1 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 12, image 2 of 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: step 12, image 3 of 3
      • Pull button cover off of the button frame.
      Ask FixBot
Brandon Benavente
704 Reputation
6 Guides authored
USF Tampa, Team 3-6, Sullivan Spring 2016 Member of USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 1,523
