Fujifilm FinePix F505EXR Selector Button Replacement
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Battery: step 1, image 1 of 2 Fujifilm FinePix F505EXR Selector Button Replacement, Battery: step 1, image 2 of 2
      • Power the device down before taking any other actions.
      • Hold the camera with the lens facing towards youself.
      • Turn the camera upside down and place your right thumb on the battery chamber cover.
      Ask FixBot
    2. Fujifilm FinePix F505EXR Selector Button Replacement: step 2, image 1 of 2 Fujifilm FinePix F505EXR Selector Button Replacement: step 2, image 2 of 2
      • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
      • Pull the cover entirely out and release it to reveal the battery.
      Ask FixBot
    3. Fujifilm FinePix F505EXR Selector Button Replacement: step 3, image 1 of 2 Fujifilm FinePix F505EXR Selector Button Replacement: step 3, image 2 of 2
      • Locate the orange battery latch that holds the battery in place.
      • Use your finger to push the latch away from yourself to release the battery.
      • Remove the battery manually from the battery chamber.
      • Place the battery into a charger if it is dead.
      • Remove battery before performing any other repairs.
      Ask FixBot
      • Replace defective battery if previous steps fail
      • Contact support on the Fujifilm website for further assistance
      Ask FixBot
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: step 5, image 1 of 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: step 5, image 2 of 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: step 5, image 3 of 3
      • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
      • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
      • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
      Ask FixBot
    2. Fujifilm FinePix F505EXR Selector Button Replacement: step 6, image 1 of 2 Fujifilm FinePix F505EXR Selector Button Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
      • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
      • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
      • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
      • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
      Ask FixBot
    3. Fujifilm FinePix F505EXR Selector Button Replacement: step 7, image 1 of 1
      • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
      • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
      Ask FixBot
    4. Fujifilm FinePix F505EXR Selector Button Replacement: step 8, image 1 of 3 Fujifilm FinePix F505EXR Selector Button Replacement: step 8, image 2 of 3 Fujifilm FinePix F505EXR Selector Button Replacement: step 8, image 3 of 3
      • Lift the chip with tweezers to remove it from the other remaining components.
      Ask FixBot
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button: step 9, image 1 of 1
      • After the selector button circuit board is taken out. There will be a black rubber display for the front buttons, remove this.
      Ask FixBot
    2. Fujifilm FinePix F505EXR Selector Button Replacement: step 10, image 1 of 2 Fujifilm FinePix F505EXR Selector Button Replacement: step 10, image 2 of 2
      • After taking the rubber button selector out, there will still be a circular metal selector button. This is what makes the camera delete pictures and do various tasks. Remove this and set aside.
      Ask FixBot
    3. Fujifilm FinePix F505EXR Selector Button Replacement: step 11, image 1 of 1
      • Finally replace the selector button with the new replacement.
      Ask FixBot
Brittany Perkins
310 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 667
