Fujifilm FinePix AX665 Sensor Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
64
All Time:
1,095
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
The sensor of the camera detects and conveys information used to make an image. If the sensor is damaged, the camera can not take a picture properly. If your pictures are coming out dark or faded, etc., you may need to replace the sensor. Follow the steps in this guide to safely replace the sensor.
The camera will be completely open in this replacement. Make you carefully look at the pictures to see which parts you are working with, so you are not removing the wrong thing.
Tools
    1. Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 1 of 3 Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 2 of 3 Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 3 of 3
      • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
      Ask FixBot
    2. Fujifilm FinePix AX665 Sensor Replacement: step 2, image 1 of 3 Fujifilm FinePix AX665 Sensor Replacement: step 2, image 2 of 3 Fujifilm FinePix AX665 Sensor Replacement: step 2, image 3 of 3
      • Use a plastic pick to separate each side of the camera case apart.
      Ask FixBot
    3. Fujifilm FinePix AX665 Sensor Replacement: step 3, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 3, image 2 of 2
      • Remove the ribbon cable from the side of logic board.
      Ask FixBot
    4. Fujifilm FinePix AX665 Sensor Replacement: step 4, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 4, image 2 of 2
      • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
      Ask FixBot
    5. Fujifilm FinePix AX665 Sensor Replacement: step 5, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 5, image 2 of 2
      • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
      Ask FixBot
    6. Fujifilm FinePix AX665 Sensor Replacement: step 6, image 1 of 1
      • Remove the three screws holding the sensor.
      Ask FixBot
    7. Fujifilm FinePix AX665 Sensor Replacement: step 7, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 7, image 2 of 2
      • Remove the sensor ribbon cable from the logic board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 1,095
