Fujifilm FinePix Z90 Lens cover/case Replacement
  1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: step 1, image 1 of 2 Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: step 1, image 2 of 2
    • Use a small #000 Phillips screwdriver to take the screws out. Keep all the screws in a container and the two different types separate.
    • Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
    Ask FixBot
  2. Fujifilm  FinePix Z90 Lens cover/case Replacement: step 2, image 1 of 2 Fujifilm  FinePix Z90 Lens cover/case Replacement: step 2, image 2 of 2
    • Take the two screws on the left side and the two screws on the bottom of the camera.
    Ask FixBot
  3. Fujifilm  FinePix Z90 Lens cover/case Replacement: step 3, image 1 of 2 Fujifilm  FinePix Z90 Lens cover/case Replacement: step 3, image 2 of 2
    • By now you will have the front case and the back case separated from each other.
    Ask FixBot
Sam Clark
301 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-6, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G6
2 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 647
