FujiFilm FinePix XP50 Motherboard Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
94
All Time:
2,112
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The motherboard connects everything in the camera together. A working Motherboard is essential for the camera to function properly as a complete unit.
Tools
    1. FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: step 1, image 1 of 3 FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: step 1, image 2 of 3 FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: step 1, image 3 of 3
      • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
      • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
      Ask FixBot
    2. FujiFilm FinePix XP50 Motherboard  Replacement: step 2, image 1 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 2, image 2 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 2, image 3 of 3
      • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
      • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
      Ask FixBot
    3. FujiFilm FinePix XP50 Motherboard  Replacement: step 3, image 1 of 1
      • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
      Ask FixBot
    4. FujiFilm FinePix XP50 Motherboard  Replacement: step 4, image 1 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 4, image 2 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 4, image 3 of 3
      • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
      • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
      • Once both screws are removed the silver side casing will slide off.
      Ask FixBot
    5. FujiFilm FinePix XP50 Motherboard  Replacement: step 5, image 1 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 5, image 2 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 5, image 3 of 3
      Ask FixBot
    6. FujiFilm FinePix XP50 Motherboard  Replacement: step 6, image 1 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 6, image 2 of 3 FujiFilm FinePix XP50 Motherboard  Replacement: step 6, image 3 of 3
      • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
      • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
      • The rear panel is now free from the camera.
      Ask FixBot
    1. FujiFilm FinePix XP50 Motherboard  Replacement, Motherboard: step 7, image 1 of 1
      • Using Phillips #00 screwdriver, remove four 3.0 mm screws holding motherboard in place.
      Ask FixBot
    2. FujiFilm FinePix XP50 Motherboard  Replacement: step 8, image 1 of 1
      • Insert the spudger in between the side case pannel and the motherboard.
      • Move the spudger in an upward motion to pry the motherboard out of the plastic housing. Work all the way around the motherboard until the motherboard is free.
      Ask FixBot
    3. FujiFilm FinePix XP50 Motherboard  Replacement: step 9, image 1 of 2 FujiFilm FinePix XP50 Motherboard  Replacement: step 9, image 2 of 2
      • There are four wires that are soldered to the motherboard. Detach these wires from the motherboard by desoldering them.This will free the motherboard.
      • For instructions on desoldering see How To Solder and Desolder Connections
      Ask FixBot
2 other people completed this guide.
Catherine Daniel
396 Reputation
3 Guides authored
Baylor, Team 2-4, Grigsby Spring 2015 Member of Baylor, Team 2-4, Grigsby Spring 2015
BU-GRIGSBY-S15S2G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 94
All Time: 2,112
