FujiFilm FinePix XP50 LCD Screen Replacement
  1. FujiFilm FinePix XP50 LCD Screen Replacement, Rear Case: step 1, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement, Rear Case: step 1, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement, Rear Case: step 1, image 3 of 3
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
    Ask FixBot
  2. FujiFilm FinePix XP50 LCD Screen Replacement: step 2, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 2, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 2, image 3 of 3
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
    Ask FixBot
  3. FujiFilm FinePix XP50 LCD Screen Replacement: step 3, image 1 of 1
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
    Ask FixBot
  4. FujiFilm FinePix XP50 LCD Screen Replacement: step 4, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 4, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 4, image 3 of 3
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
    Ask FixBot
  5. FujiFilm FinePix XP50 LCD Screen Replacement: step 5, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 5, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 5, image 3 of 3
    Ask FixBot
  6. FujiFilm FinePix XP50 LCD Screen Replacement: step 6, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 6, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement: step 6, image 3 of 3
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
    Ask FixBot
  7. FujiFilm FinePix XP50 LCD Screen Replacement, LCD Screen: step 7, image 1 of 3 FujiFilm FinePix XP50 LCD Screen Replacement, LCD Screen: step 7, image 2 of 3 FujiFilm FinePix XP50 LCD Screen Replacement, LCD Screen: step 7, image 3 of 3
    • Take the spudger and wedge it in between the screen and the frame.
    • Slowly make your way around the screen with the spudger just enough to separate the screen from the frame.
    Ask FixBot
  8. FujiFilm FinePix XP50 LCD Screen Replacement: step 8, image 1 of 2 FujiFilm FinePix XP50 LCD Screen Replacement: step 8, image 2 of 2
    • Take the spudger again and wedge it in the thinner frame to pry the LCD screen from the frame.
    • Make your way around with the spudger just enough to separate the screen and frame once again.
    Ask FixBot
  9. FujiFilm FinePix XP50 LCD Screen Replacement: step 9, image 1 of 2 FujiFilm FinePix XP50 LCD Screen Replacement: step 9, image 2 of 2
    • Take the spudger and wedge it very carefully between the LCD screen and the very thin and fragile frame.
    • Very carefully make your way around the frame with the spudger, while making sure not to use too much force. Otherwise the screen will be damaged.
    Ask FixBot
  10. FujiFilm FinePix XP50 LCD Screen Replacement: step 10, image 1 of 1
    • Detach the LCD screen from the motherboard by detaching the orange ribbon.
    Ask FixBot
Catherine Daniel
396 Reputation
3 Guides authored
Baylor, Team 2-4, Grigsby Spring 2015 Member of Baylor, Team 2-4, Grigsby Spring 2015
BU-GRIGSBY-S15S2G4
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 54
All Time: 1,443
