FujiFilm FinePix XP10SE Lens Replacement
    1. FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 1 of 3 FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 2 of 3 FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 3 of 3
      • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
      • Use a T5 Torx bit to secure the exterior decorative cover of the device.
      Ask FixBot
    2. FujiFilm FinePix XP10SE Lens Replacement: step 2, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to detach the case.
      Ask FixBot
    3. FujiFilm FinePix XP10SE Lens Replacement: step 3, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to cautiously pry the casing off of the camera.
      Ask FixBot
    4. FujiFilm FinePix XP10SE Lens Replacement: step 4, image 1 of 3 FujiFilm FinePix XP10SE Lens Replacement: step 4, image 2 of 3 FujiFilm FinePix XP10SE Lens Replacement: step 4, image 3 of 3
      • Carefully slide the case to the left. Avoid cracking the case on the lens.
      Ask FixBot
    1. FujiFilm FinePix XP10SE Lens Replacement, Lens: step 5, image 1 of 1
      • Remove the screws from the lens cover
      Ask FixBot
    2. FujiFilm FinePix XP10SE Lens Replacement: step 6, image 1 of 1
      • Remove the screws from the side metal cover of outer case.
      Ask FixBot
    3. FujiFilm FinePix XP10SE Lens Replacement: step 7, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 7, image 2 of 2
      • Gently remove the Lens from the housing.
      Ask FixBot
Bryan
598 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 433
