FujiFilm FinePix S5100 Lens Compartment Replacement
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, Battery: step 1, image 1 of 1
      • Ensure your camera is in the off position.
      • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
      Ask FixBot
      • Open the battery door by pushing down and in the direction of the arrow on the door.
      Ask FixBot
    2. FujiFilm FinePix S5100 Lens Compartment Replacement: step 3, image 1 of 1
      • Remove four AA batteries from the camera.
      Ask FixBot
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, Back Cover: step 4, image 1 of 1
      • Turn the camera so the screen is facing you and the camera lens is facing away from you.
      Ask FixBot
    2. FujiFilm FinePix S5100 Lens Compartment Replacement: step 5, image 1 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement: step 5, image 2 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement: step 5, image 3 of 3
      • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
      • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
      • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
      • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
      Ask FixBot
    3. FujiFilm FinePix S5100 Lens Compartment Replacement: step 6, image 1 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement: step 6, image 2 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement: step 6, image 3 of 3
      • Carefully pull the back cover and separate it from the rest of the camera body.
      • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
      Ask FixBot
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, LCD Screen: step 7, image 1 of 2 FujiFilm FinePix S5100 Lens Compartment Replacement, LCD Screen: step 7, image 2 of 2
      • Remove the two 1.3mm Phillips #000 screws from the LCD frame.
      Ask FixBot
    2. FujiFilm FinePix S5100 Lens Compartment Replacement: step 8, image 1 of 2 FujiFilm FinePix S5100 Lens Compartment Replacement: step 8, image 2 of 2
      • Carefully using your hand, grab the LCD screen and pull upward and away from the motherboard.
      • Carefully using your hand, remove the tan digital tape by disconnecting it from the receiving port.
      • Remove the entire LCD screen from the motherboard.
      Ask FixBot
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, Battery Compartment: step 9, image 1 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement, Battery Compartment: step 9, image 2 of 3 FujiFilm FinePix S5100 Lens Compartment Replacement, Battery Compartment: step 9, image 3 of 3
      • Remove the single 1.3mm Phillips #000 screw.
      • Carefully remove the battery compartment from the rest of the camera.
      Ask FixBot
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, Motherboard: step 10, image 1 of 2 FujiFilm FinePix S5100 Lens Compartment Replacement, Motherboard: step 10, image 2 of 2
      • Carefully grab and remove the upper level motherboard from the camera.
      Ask FixBot
    2. FujiFilm FinePix S5100 Lens Compartment Replacement: step 11, image 1 of 1
      • Remove three 0.8mm Phillips #000 screws from the motherboard.
      Ask FixBot
    3. FujiFilm FinePix S5100 Lens Compartment Replacement: step 12, image 1 of 2 FujiFilm FinePix S5100 Lens Compartment Replacement: step 12, image 2 of 2
      • Carefully remove the tan digital tape from the receiving port.
      Ask FixBot
    4. FujiFilm FinePix S5100 Lens Compartment Replacement: step 13, image 1 of 1
      • Carefully remove the lower level motherboard from the camera and set aside.
      Ask FixBot
    1. FujiFilm FinePix S5100 Lens Compartment Replacement, Lens Compartment: step 14, image 1 of 2 FujiFilm FinePix S5100 Lens Compartment Replacement, Lens Compartment: step 14, image 2 of 2
      • Remove three 1.0mm Phillips #000 black screws from the back of the lens compartment.
      • Remove two 0.4mm Phillips #000 red screws from the back of the lens compartment.
      Ask FixBot
    2. FujiFilm FinePix S5100 Lens Compartment Replacement: step 15, image 1 of 1
      • Carefully grab the metal brace and push upward to lift the metal brace off of the hook.
      Ask FixBot
    3. FujiFilm FinePix S5100 Lens Compartment Replacement: step 16, image 1 of 1
      • Carefully remove the lens compartment from the camera body.
      Ask FixBot
Kristen Gismondi
108,488 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
78,495 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 586
