FujiFilm FinePix S5100 Battery Compartment Replacement
    1. FujiFilm FinePix S5100 Battery Compartment Replacement, Battery: step 1, image 1 of 1
      • Ensure your camera is in the off position.
      • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
      Ask FixBot
      • Open the battery door by pushing down and in the direction of the arrow on the door.
      Ask FixBot
    2. FujiFilm FinePix S5100 Battery Compartment Replacement: step 3, image 1 of 1
      • Remove four AA batteries from the camera.
      Ask FixBot
    1. FujiFilm FinePix S5100 Battery Compartment Replacement, Back Cover: step 4, image 1 of 1
      • Turn the camera so the screen is facing you and the camera lens is facing away from you.
      Ask FixBot
    2. FujiFilm FinePix S5100 Battery Compartment Replacement: step 5, image 1 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement: step 5, image 2 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement: step 5, image 3 of 3
      • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
      • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
      • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
      • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
      Ask FixBot
    3. FujiFilm FinePix S5100 Battery Compartment Replacement: step 6, image 1 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement: step 6, image 2 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement: step 6, image 3 of 3
      • Carefully pull the back cover and separate it from the rest of the camera body.
      • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
      Ask FixBot
    1. FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: step 7, image 1 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: step 7, image 2 of 3 FujiFilm FinePix S5100 Battery Compartment Replacement, Battery Compartment: step 7, image 3 of 3
      • Remove the single 1.3mm Phillips #000 screw.
      • Carefully remove the battery compartment from the rest of the camera.
      Ask FixBot
Kristen Gismondi
108,497 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
81,372 Guides authored
1 Guide Comment
Will this process be the same for the S3300 and can you recommend the best place to purchase a replacement part?
Lauren Higgins - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,213
