FujiFilm FinePix S4500 LCD Replacement
  1. FujiFilm FinePix S4500 LCD Replacement, LCD: step 1, image 1 of 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
    Ask FixBot
  2. FujiFilm FinePix S4500 LCD Replacement: step 2, image 1 of 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
    Ask FixBot
  3. FujiFilm FinePix S4500 LCD Replacement: step 3, image 1 of 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
    Ask FixBot
  4. FujiFilm FinePix S4500 LCD Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
    Ask FixBot
  5. FujiFilm FinePix S4500 LCD Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
    Ask FixBot
  6. FujiFilm FinePix S4500 LCD Replacement: step 6, image 1 of 2 FujiFilm FinePix S4500 LCD Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
    Ask FixBot
  7. FujiFilm FinePix S4500 LCD Replacement: step 7, image 1 of 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
    Ask FixBot
  8. FujiFilm FinePix S4500 LCD Replacement: step 8, image 1 of 2 FujiFilm FinePix S4500 LCD Replacement: step 8, image 2 of 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
    Ask FixBot
Vicente Rios
708 Reputation
6 Guides authored
Cal Poly, Team 9-4, Banghart Winter 2017 Member of Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 20
All Time: 936
