FujiFilm FinePix A340 Outer Case Replacement
    1. FujiFilm FinePix A340 Outer Case Replacement, Outer Case: step 1, image 1 of 1
      • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
      • Slide the battery cover to the side to release the batteries.
      Ask FixBot
    2. FujiFilm FinePix A340 Outer Case Replacement: step 2, image 1 of 3 FujiFilm FinePix A340 Outer Case Replacement: step 2, image 2 of 3 FujiFilm FinePix A340 Outer Case Replacement: step 2, image 3 of 3
      • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
      Ask FixBot
    3. FujiFilm FinePix A340 Outer Case Replacement: step 3, image 1 of 2 FujiFilm FinePix A340 Outer Case Replacement: step 3, image 2 of 2
      • Grab the case with your hands and slowly pull back the outer casing.
      Ask FixBot
Cody
47 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Spring 2010 Member of Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Members
44 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 49
All Time: 4,214
