FujiFilm FinePix A340 Motherboard Replacement
    1. FujiFilm FinePix A340 Motherboard Replacement, Outer Case: step 1, image 1 of 1
      • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
      • Slide the battery cover to the side to release the batteries.
      Ask FixBot
    2. FujiFilm FinePix A340 Motherboard Replacement: step 2, image 1 of 3 FujiFilm FinePix A340 Motherboard Replacement: step 2, image 2 of 3 FujiFilm FinePix A340 Motherboard Replacement: step 2, image 3 of 3
      • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
      Ask FixBot
    3. FujiFilm FinePix A340 Motherboard Replacement: step 3, image 1 of 2 FujiFilm FinePix A340 Motherboard Replacement: step 3, image 2 of 2
      • Grab the case with your hands and slowly pull back the outer casing.
      Ask FixBot
    1. FujiFilm FinePix A340 Motherboard Replacement, LCD Screen: step 4, image 1 of 1
      • Locate the LCD screen and anchoring screw.
      • Remove screw.
      Ask FixBot
    2. FujiFilm FinePix A340 Motherboard Replacement: step 5, image 1 of 1
      • Carefully pull the LCD screen away from the board it is connected to.
      Ask FixBot
    3. FujiFilm FinePix A340 Motherboard Replacement: step 6, image 1 of 1
      • Push both blue switches away from the holding device to detach the LCD ribbon.
      • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
      Ask FixBot
    4. FujiFilm FinePix A340 Motherboard Replacement: step 7, image 1 of 1
      • Carefully detach the ribbon from where it was connected by the blue pins.
      Ask FixBot
    5. FujiFilm FinePix A340 Motherboard Replacement: step 8, image 1 of 1
      • Now that everything has been disconnected from the board, remove LCD screen.
      Ask FixBot
    1. FujiFilm FinePix A340 Motherboard Replacement, Motherboard: step 9, image 1 of 1
      • Remove the two screws holding the circuit board down.
      Ask FixBot
    2. FujiFilm FinePix A340 Motherboard Replacement: step 10, image 1 of 2 FujiFilm FinePix A340 Motherboard Replacement: step 10, image 2 of 2
      • Remove the black sticky tape from the circuit board and camera case.
      Ask FixBot
    3. FujiFilm FinePix A340 Motherboard Replacement: step 11, image 1 of 2 FujiFilm FinePix A340 Motherboard Replacement: step 11, image 2 of 2
      • Gently pull the circuit board away from the front side of the camera.
      • Be careful when removing the assembly as to not break any solder leads or damage the lens assembly.
      Ask FixBot
    4. FujiFilm FinePix A340 Motherboard Replacement: step 12, image 1 of 2 FujiFilm FinePix A340 Motherboard Replacement: step 12, image 2 of 2
      • Remove the motherboard by pulling it straight away from the assembly.
      Ask FixBot
Cody
47 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Spring 2010 Member of Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 4,255
