Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓The Fugoo Tough XL speaker has an external shell that can be removed to make necessary repairs.
Tools
There are four 3 mm screws located at each corner of the device
Using a 3 mm hex screwdriver remove all four of the screws on the device
Remove the internal device from the outer casing.
There are four twelve mm screws on each corner of the device
Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
There are right six mm screws on the top and the bottom of this device
Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
