Fugoo Tough Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
93
All Time:
908
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Fugoo Tough Power Button Replacement, Power Button: step 1, image 1 of 3 Fugoo Tough Power Button Replacement, Power Button: step 1, image 2 of 3 Fugoo Tough Power Button Replacement, Power Button: step 1, image 3 of 3
      • Begin by unscrewing the four 10.72 mm corner screws using the Hex 2.0 screwdriver.
      • Using the Hex 1.5 screwdriver, remove the remaining six 5.79 mm screws on the front of the speaker.
      • Pull the front part of shell away from the back part of shell.
      Ask FixBot
    2. Fugoo Tough Power Button Replacement: step 2, image 1 of 3 Fugoo Tough Power Button Replacement: step 2, image 2 of 3 Fugoo Tough Power Button Replacement: step 2, image 3 of 3
      • Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
      • Pull on the speaker covers to remove them.
      • Rotate the speaker 180 degrees and then remove the four 5.57 mm screws on the side speaker that has the power/bluetooth buttons.
      • Pull apart the side speaker and its casing away from the body of the Fugoo.
      Ask FixBot
    3. Fugoo Tough Power Button Replacement: step 3, image 1 of 2 Fugoo Tough Power Button Replacement: step 3, image 2 of 2
      • After pulling apart the side speaker and its casing, you will see both the power and Bluetooth buttons on the underside of the circuit board.
      • Desolder the power button and replace it on the motherboard.
      Ask FixBot
2 Guide Comments
Where can I buy the screwdrivers to remove the 4-5.57mm screws?
Frank Peñalo - Reply Share
Where can you find/source replacement power switches?
ginj - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 93
All Time: 908
