Fugoo Tough Battery Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
36
Past 30 Days:
112
All Time:
5,460
Comments: 10
10 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the battery of the Fugoo Tough.
Tools
    1. Fugoo Tough Battery Replacement, Battery: step 1, image 1 of 3 Fugoo Tough Battery Replacement, Battery: step 1, image 2 of 3 Fugoo Tough Battery Replacement, Battery: step 1, image 3 of 3
      • Begin by unscrewing the four 10.72mm corner screws using the Hex 2.0 screwdriver.
      • Using the Hex 1.5 screwdriver, remove the remaining six 5.79mm screws on the front of the speaker.
      • Pull the front part of shell away from the back part of shell.
      Ask FixBot
    2. Fugoo Tough Battery Replacement: step 2, image 1 of 3 Fugoo Tough Battery Replacement: step 2, image 2 of 3 Fugoo Tough Battery Replacement: step 2, image 3 of 3
      • Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
      • Pull on the speaker covers to remove them.
      • Rotate to side the speaker that has the charging port. Remove the four 5.57mm screws facing you.
      • Rotate the speaker 180 degrees and then remove the four 5.57 screws on the side speaker that has the power/bluetooth buttons.
      Ask FixBot
    3. Fugoo Tough Battery Replacement: step 3, image 1 of 3 Fugoo Tough Battery Replacement: step 3, image 2 of 3 Fugoo Tough Battery Replacement: step 3, image 3 of 3
      • Have back of speaker facing you, remove 5-12.70mm screws using 1/16 flat head screwdriver.
      • Using the plastic opening tool, you will be able to wedge back face of speaker off.
      Ask FixBot
    4. Fugoo Tough Battery Replacement: step 4, image 1 of 3 Fugoo Tough Battery Replacement: step 4, image 2 of 3 Fugoo Tough Battery Replacement: step 4, image 3 of 3
      • The circuit board will be revealed, you will notice the various clips/wires that go to the speakers and the battery
      • Remove the blue "clip" from the mother board, then pull the on the speaker and remove it, to give you more room to work
      • Gently pull down on the largest bundle of wires connected to the mother board by a white clip.
      • Battery isn't anchored down, you will be able to pull it out of device
      • The battery can now be replaced
      Ask FixBot
10 Guide Comments
Is it waterproof afterwards?
TM M - Reply Share
what are the battery specs? where can one be purchased?
Miguel Tenorio - Reply Share
Looks like an 18650 battery with wires soldered to a plastic housing that connects the 2 poles. The battery is slightly thicker but I think it's the wrap around it to keep it as a single unit. Mine just went bad so I'm going to try to swap it out. I'll update if I'm Successful.
Damian - Reply Share
Update: Success! Worked beautifully. I'll put together some pix I took to wrap it up. If you kinda put it together and test it but the bass is all gone, give it a squeeze. Bass doesn't really show back up til you put screws back in.
What battery did you get? 18650? maH?
Tristan Mendoza - Reply Share
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 112
All Time: 5,460
