Fugoo Style XL Motherboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
86
All Time:
1,251
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to remove and replace the motherboard within a Fugoo Style XL.
Tools
    1. Fugoo Style XL Motherboard Replacement, Fabric Case: step 1, image 1 of 2 Fugoo Style XL Motherboard Replacement, Fabric Case: step 1, image 2 of 2
      • Using your hand, unscrew the large screws underneath the speaker.
      Ask FixBot
    2. Fugoo Style XL Motherboard Replacement: step 2, image 1 of 3 Fugoo Style XL Motherboard Replacement: step 2, image 2 of 3 Fugoo Style XL Motherboard Replacement: step 2, image 3 of 3
      • Using your hand, gently lift the large plastic tab secured to the rubber holding.
      • After lifting the tab, slide the speaker out of its case.
      • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
      Ask FixBot
    1. Fugoo Style XL Motherboard Replacement, Motherboard: step 3, image 1 of 2 Fugoo Style XL Motherboard Replacement, Motherboard: step 3, image 2 of 2
      • Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
      Ask FixBot
    2. Fugoo Style XL Motherboard Replacement: step 4, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 4, image 2 of 2
      • Using your hand, pull the covers away from the speaker.
      Ask FixBot
    3. Fugoo Style XL Motherboard Replacement: step 5, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 5, image 2 of 2
      • Use a #2.0 Hex screwdriver to unscrew the 8 screws shown in the image.
      Ask FixBot
    4. Fugoo Style XL Motherboard Replacement: step 6, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 6, image 2 of 2
      • Gently pull apart the front casing from the back casing.
      • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
      Ask FixBot
    5. Fugoo Style XL Motherboard Replacement: step 7, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
      • When the red bundled cable connectors are disconnected, set the outer casing aside.
      Ask FixBot
    6. Fugoo Style XL Motherboard Replacement: step 8, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 8, image 2 of 2
      • Untangle any blue bundled cable connectors and gently remove them from the motherboard using a pair of tweezers.
      Ask FixBot
    7. Fugoo Style XL Motherboard Replacement: step 9, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 9, image 2 of 2
      • Carefully untangle and remove the white bundled cable connectors from the motherboard.
      Ask FixBot
    8. Fugoo Style XL Motherboard Replacement: step 10, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 10, image 2 of 2
      • Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
      • Using your hand, carefully remove the midwoofers.
      Ask FixBot
    9. Fugoo Style XL Motherboard Replacement: step 11, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 11, image 2 of 2
      • Using a pair of tweezers, lift the padded holding that secures the ZIF connector to the motherboard. The connector will release from the motherboard once the padding is lifted.
      • Do not pull on the cables themselves. Doing so can damage the cables. Always remove the ZIF connector by gently lifting the padding securing them to the motherboard.
      Ask FixBot
    10. Fugoo Style XL Motherboard Replacement: step 12, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 12, image 2 of 2
      • Carefully lift the battery and motherboard unit halfway out of the casing. The motherboard is connected to the battery directly.
      • There is a small coaxial cable connected underneath the motherboard. Using a pair of tweezers, carefully disconnect and remove the cable from under the adhesive tape.
      • When the cable is disconnected, fully remove the motherboard and battery unit.
      Ask FixBot
    11. Fugoo Style XL Motherboard Replacement: step 13, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 13, image 2 of 2
      • Remove the 3mm screws using a #2.0 Hex screwdriver. There are 4 of these screws (2 on each side) that connect the motherboard to the battery unit.
      • When the screws are removed, use an iFixit opening tool to remove the motherboard from the two clamps securing it to the battery pack.
      • Beware! The motherboard is not fully disconnected from the battery even when removed from the clamps.
      Ask FixBot
    12. Fugoo Style XL Motherboard Replacement: step 14, image 1 of 2 Fugoo Style XL Motherboard Replacement: step 14, image 2 of 2
      • Using tweezers or your hand, carefully disconnect the bundled cables connecting the battery to the motherboard.
      Ask FixBot
James Gifford
573 Reputation
5 Guides authored
USF Tampa, Team S3-G4, Cannon Fall 2017 Member of USF Tampa, Team S3-G4, Cannon Fall 2017
USFT-CANNON-F17S3G4
4 Members
60 Guides authored
3 Guide Comments
Where can I purchase a replacement mother board?
Vincent walcott - Reply Share
Are you allowed to tell us where you found a motherboard? I can not find one anywhere for my fugoo
Rhett Mccrady - Reply Share
A repair guy lost my charging board, is there a way I can bypass it? Or Where can I get a replacement?
David Langat - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,251
