Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Fuel Tank Removal
Views: 3.2K
View statistics:
Past 24 Hours:
11
Past 7 Days:
74
Past 30 Days:
355
All Time:
3,219
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Fuel Tank Removal
Introduction
Go to step 1 ↓
The tank must be drained first.
      • Remove the fuel filler cap.
      • Remove the two screws from the fuel filler neck.
      Ask FixBot
    1. Fuel Tank Removal, Remove the rear right wheel arch liner: step 2, image 1 of 1
      • Undo the following snap fits.
      • Undo the following screws.
      Ask FixBot
    2. Fuel Tank Removal, Remove the underbody shield: step 3, image 1 of 1
      • Remove the following screws.
      Ask FixBot
      • The fuel vapor absorber.
      Ask FixBot
      • The fuel pump/gauge connector.
      • The fuel line.
      Ask FixBot
      • Spread the brake hose bracket.
      Ask FixBot
      • Lower the fuel tank, preferably using a transmission jack.
      • Disconnect the fuel tank power cable.
      • Finally, remove the fuel tank.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Author
with
DocTwingo
8,264 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 74
Past 30 Days: 355
All Time: 3,219
