Up to 20% off select tools
Front Inner Tube Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
47
Past 30 Days:
216
All Time:
4,148
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Here's an easy step by step tutorial on removing and replacing the inner tube.
    1. Front Inner Tube Replacement, Front Inner Tube: step 1, image 1 of 2 Front Inner Tube Replacement, Front Inner Tube: step 1, image 2 of 2
      • First, remove the front wheel from the frame by unscrewing the adjustable screw
      Ask FixBot
    2. Front Inner Tube Replacement: step 2, image 1 of 3 Front Inner Tube Replacement: step 2, image 2 of 3 Front Inner Tube Replacement: step 2, image 3 of 3
      • Next, wedge tire tool below the bike wheel, right above the rim.
      • Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
      • Following this, grab the 2nd tire tool and place it into the gap you have created.
      • Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
      Ask FixBot
    3. Front Inner Tube Replacement: step 3, image 1 of 2 Front Inner Tube Replacement: step 3, image 2 of 2
      • After removing the bike tire, locate the bike valve used to pump air into the tire.
      • Gently remove the inner tube starting with the area around the valve.
      • Make a note of where the hole for the valve is located on the bike rim, because that is where the next step begins.
      Ask FixBot
    4. Front Inner Tube Replacement: step 4, image 1 of 1
      • Pump a small amount of air into the new bike tube so that it is easier to work with.
      • Next, locate the hole in the bike rim and feed the valve through and into position.
      • Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
      Ask FixBot
    5. Front Inner Tube Replacement: step 5, image 1 of 2 Front Inner Tube Replacement: step 5, image 2 of 2
      • Finish by placing the bike tire back on the the frame, while making sure that no fold or creases form in the tube.
      • Lastly, pump air into the tire and remount onto bike frame.
      Ask FixBot
To reassemble your device, follow these instructions.
4 other people completed this guide.
Author
with
Theo Tzeng
74 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 216
All Time: 4,148
