Introduction
Go to step 1 ↓If your 2012–2018 Frigidaire/Electrolux French-door refrigerator is making ice very slowly, stops making ice, or the ice bucket won’t come out because it’s frozen in, the usual cause is frost and moisture buildup in the ice box and evaporator cover area. This guide walks through quick thawing steps (forced defrost and steaming), then deeper disassembly, inspection, and a long-term repair using an OEM icemaker repair kit and an OEM icemaker if needed. These instructions were written using a French-door model with the icemaker in the fresh-food compartment, so other models may have minor differences.
Step 2 Decide whether to start with a thaw
Start with thawing if the ice bucket is stuck, the ice box is packed with frost, or ice can’t dispense.
Move to the deeper inspection and repair steps if the problem keeps returning every few weeks.
Step 3 Run forced defrost mode
Press and hold the two buttons on the right side of the control panel for about 12 seconds.
Listen for the fans to shut off, then confirm that “DF” appears on the display.
Press and hold the same two buttons for about 10 seconds to stop forced defrost and clear “DF.”
Step 4 Thaw the ice chute with steam
Insert a garment steamer nozzle into the ice dispense opening and press the trigger to melt the ice blockage.
Step 5 Move to a long-term fix if frost returns
Continue with disassembly and inspection if the icemaker works briefly after thawing but freezes up again.
Step 6 Remove the icemaker front cover
Use a Phillips screwdriver to remove the two screws from the icemaker facade.
Lift the facade up, then pull it out to remove it.
Step 7 Remove the wire cover and unplug the icemaker
Use a 1/4" nut driver to remove the screw on the left side of the icemaker area.
Use a 1/4" nut driver to remove the screw that secures the wire cover on top.
Pull the wire cover down, then away, to release the rear tabs.
Press the clips to disconnect the two wire harnesses inside the icemaker area.
Step 8 Remove the icemaker assembly
Pull the icemaker assembly out by pulling on the top chassis, not the ice tray area.
Cut the cable ties that secure the wire trunk on the right side using side snips or scissors.
Remove the icemaker from the compartment.
Replace the icemaker if it’s cracked or damaged.
Step 9 Remove the ice box
Use a 1/4" nut driver to remove the two screws at the top front of the cabinet.
Route the two disconnected wire harnesses through the small hole at the top of the ice box.
Pull the ice box forward and out while keeping the rear wire harness from snagging.
Step 10 Remove the air handler housing
Use a 1/4" nut driver to remove the three screws holding the air handler housing.
Use a 12 inch extension to reach the upper-left screw because clearance is very tight.
Thaw heavy ice buildup with a garment steamer, a box fan, or a hairdryer on the coolest setting if the housing is frozen in place.
Depress the two side tabs to disconnect the left-side wire harness from the air handler, then remove the housing.
Step 11 Remove the evaporator cover
Use a screwdriver or needle-nose pliers to press in the plastic tab on the wire harness retainer.
Push the wire harness rearward to free it from the evaporator cover.
Slide the evaporator cover downward to remove it.
Use steam, cool airflow, or very low heat to melt ice on the coils until the cover slides off easily.
Step 12 Inspect for air gaps and clear the drain
Inspect the bottom of the evaporator cover for damage that could let moisture into the ice box area.
Inspect the drain line area at the bottom because it often freezes and causes extra moisture buildup.
Flush the drain with warm water to confirm it flows freely.
Inspect the area behind the refrigerator for rust from trapped moisture, and dry it out if possible.
Step 13 Inspect and test the defrost sensor
Inspect the defrost sensor at the top, and replace it if it looks damaged or swollen.
Press the sensor wires out from inside the harness using a very small screwdriver or a connector pick to remove it.
Test the sensor for continuity when it’s extremely cold, such as in a glass of ice water.
Step 14 Choose an OEM kit for recurring frost
Plan to install an OEM icemaker repair kit if frost and ice buildup returns regularly and you see a heavy frost pattern on the back.
Step 15 Remove the auger fork from the old air handler
Remove the metal fork from the auger by loosening its countersunk screw.
Use a strong screwdriver between the fork tongs, tap the handle with a hammer to dislodge the fork, then unscrew it.
Step 16 Remove the auger and free the wire trunk
Use a 1/4" nut driver to remove the three auger screws, including the one hidden behind the foam strip.
Use a flathead screwdriver to press the rubber grommet inward and release the wire trunk from the housing.
Disconnect the small fan wire, the two solenoid wires, and the two auger motor wires to make the rebuild easier.
Step 17 Remove the fan solenoid and bucket glide
Remove the small Phillips screw and lift out the white bucket glide.
Use a 1/4" nut driver to remove the two screws holding the solenoid, then lift the solenoid out.
Step 18 Prepare the new air handler housing
Check whether the new air handler has gaskets pre-installed, and install any missing gaskets if needed.
Remove the black foam gasket from the new housing if it blocks fan installation.
Press the gasket out from the front grill area using a screwdriver.
Route the wire trunk through the new housing the same way it was routed on the original housing.
Step 19 Install the solenoid in the new housing
Slide the white plastic piece onto the air handler fingers, then seat the solenoid in its only correct orientation.
Install the two solenoid screws using a 1/4" nut driver.
Reconnect the two solenoid wires because the wire orientation doesn’t matter.
Step 20 Install the auger motor and guide
Fit the auger motor into the housing so the shaft protrudes through the front opening.
Align the three mounting holes, then reinstall the three black 1/4" screws gradually so all holes line up.
Slot the plastic auger guide into the bottom slot and secure it with its Phillips screw.
Step 21 Install the fan and foam gaskets
Fit the fan into the silicone gasket so the gasket’s corner triangles seat over the fan corners.
Seat the fan into the black foam gasket with the fan label facing the front, and route the harness into the side channel.
Press the foam gasket assembly into the housing using the alignment notch, and route the fan wire into its notch or channel.
Press until the plastic retainers snap the foam gasket into place.
Step 22 Reinstall the auger fork and remaining gaskets
Install the foam gasket strip that hides the auger motor screw area.
Install the gasket on the bottom of the air handler housing.
Reinstall the metal auger fork and turn the countersunk screw counterclockwise to tighten it.
Step 23 Assemble and insulate the evaporator cover
Press the new wire harness holder into the evaporator cover and rotate it 90 degrees until it snaps in place.
Join the evaporator clamshell pieces together with the harness holder oriented for later installation.
Apply metal tape strips lengthwise to insulate the left side, right side, and angled bottom pieces.
Step 24 Re-insulate the top and rear of the ice box
Remove old tape and foam gasket material from the top of the ice box, using a putty knife if needed.
Prepare the square foam gasket by removing its tape backing and knocking out the middle foam area.
Stick the square foam gasket onto the top of the ice box where the old foam was removed.
Use remaining metal tape to insulate the ice box areas to reduce moisture intrusion.
Remove damaged foam from the rear of the ice box using a putty knife or a hard plastic bristled brush.
Confirm the air handler perimeter gasket is firmly seated and the seams are flush with no rolled edges or air gaps.
Step 25 Install the evaporator cover assembly and route wiring
Cover the three top slots of the shelf support bracket with metal tape, extending about two inches above the slots.
Pull the two small metal fingers in the cover window outward until they’re flush to help the cover slide on as one piece.
Lift the cover high, center the bottom V-notch at the drain hole area, and slide the cover onto the evaporator.
Press the window tabs back in, by hand or with needle-nose pliers, to lock the cover to the evaporator.
Clip the wire harness into the bottom of the plastic harness holder and route sensor wires so they don’t interfere with the gasket.
Step 26 Reinstall the air handler housing
Slot the air handler drain tube into the rear drain opening, then clip the air handler wire harness into place.
Pivot the air handler up onto the evaporator area to form a proper seal.
Install the three air handler screws using a 1/4" nut driver, using only the original screw locations.
Step 27 Replace the icemaker fill line
Move to the rear of the refrigerator and disconnect the green water line from the gray or white push-to-connect fitting.
Press down the fitting collar with fingers, needle-nose pliers, or a small wrench while pulling the line upward.
Move to the front and use needle-nose pliers to pull the rubber stopper out, bringing the old fill line with it.
Coat the new fill line with dish soap and slide it into the top hole pointing toward the rear.
Pull the fill line from the rear to seat it fully because a few inches may not push through from the front.
Reconnect the line by pushing it into the fitting, then tug it back lightly without pressing the collar to confirm it locked.
Step 28 Reinstall the ice box
Slide the ice box up into place at the top of the air handler.
Tap the ice box into place with a plastic hammer if the gasket prevents it from fully seating in the rear.
Install the two top screws to lock the ice box in place using a 1/4" nut driver.
Step 29 Reinstall the icemaker and covers
Route the wire trunk through the icemaker area, then set the icemaker chassis onto the four metal posts and press rearward until it clicks.
Reconnect the two icemaker wire harnesses because they only fit one way due to different connector sizes.
Install the wire cover by engaging its two rear tabs, pivoting it into place, and installing its screw.
Install the front facade by engaging its side retention tabs, pressing it in, and lifting it to seat it.
Install the three remaining screws that secure the icemaker area and facade.
Reinstall the ice bucket.
Step 30 Optionally seal cabinet seams for extra protection
Apply a thin bead of RTV silicone sealant to the seams around the icemaker housing to reduce air and moisture leaks.
Step 31 Restore power and monitor
Turn the water supply back on and plug the refrigerator back in.
Monitor for returning frost and confirm the icemaker resumes normal ice production after the system stabilizes.
If the icemaker works again after thawing, resealing, and reassembly, keep monitoring the ice box for returning frost so you can catch any remaining air leak early. If the frost pattern returns quickly even after the housing and icemaker repairs, the remaining issue is likely in the sealing or airflow path rather than a simple temporary freeze-up. Repair didn't go as planned? Ask our Answers community for help.
