Frigidaire Gallery Water Filter Replacement
Views: 11K
View statistics:
Past 24 Hours:
10
Past 7 Days:
69
Past 30 Days:
226
All Time:
10,774
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide provides step-by-step instructions on replacing a Frigidaire Gallery water filter. This guide is needed because water filters can affect the entire fridge and it is important to know how to repair it, and how often. Typically, you should replace your refrigerator water filter every 6 months. If the filter is not cleaned regularly, deposit and scaling can build up inside the refrigerator causing it to slow down the system, affect the water flavor, and damage the fridge. You may need to change your water filter more often if you have poor water quality or you use the water and ice dispenser frequently.
    1. Frigidaire Gallery Water Filter Replacement, Water Filter: step 1, image 1 of 1
      • Locate the water filter in the back of the interior compartment.
      • It looks like a long white cylinder.
      Ask FixBot
    2. Frigidaire Gallery Water Filter Replacement: step 2, image 1 of 2 Frigidaire Gallery Water Filter Replacement: step 2, image 2 of 2
      • Push back on the compartment to remove the filter.
      • The filter will then pop out.
      • Remove the used filter and discard it.
      Ask FixBot
    3. Frigidaire Gallery Water Filter Replacement: step 3, image 1 of 3 Frigidaire Gallery Water Filter Replacement: step 3, image 2 of 3 Frigidaire Gallery Water Filter Replacement: step 3, image 3 of 3
      • Unwrap the replacement filter from its packaging.
      • Insert the replacement filter into the water filter housing.
      • You should hear an audible click when the filter is in place.
      Ask FixBot
    4. Frigidaire Gallery Water Filter Replacement: step 4, image 1 of 1
      • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
      • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 226
All Time: 10,774
