Frigidaire FFPE45B2QM Broken Hinge Replacement
    1. Frigidaire FFPE45B2QM Broken Hinge Replacement, Broken Hinge: step 1, image 1 of 1
      • Carefully pop off the cover using a spudger or other opening tool.
      Ask FixBot
    2. Frigidaire FFPE45B2QM Broken Hinge Replacement: step 2, image 1 of 1
      • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
      Ask FixBot
    3. Frigidaire FFPE45B2QM Broken Hinge Replacement: step 3, image 1 of 2 Frigidaire FFPE45B2QM Broken Hinge Replacement: step 3, image 2 of 2
      • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
      Ask FixBot
Peterluchini
568 Reputation
3 Guides authored
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-2, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G2
3 Members
15 Guides authored
1 Guide Comment
That might work on the TOP hinge, but on the bottom hinge the refrigerator would have to be tilted or laid on its side. Also, you could have used a hex socket of the appropriate size instead of the “JIS #1 screw driver“ to remove the bolts.
My refrigerator is a Whirlpool that uses top hinge bolts that require an allen wrench. The bottom is another can of worms, especially with the auto-close.
The previous Whirlpool model had a bottom hinge with a plastic / nylon piece to make it close. When it broke, I made an aluminum piece that kept the door closed.
doctordon - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 959
