Frigidaire FFHT2022AW Freezer Door Handle Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
103
All Time:
624
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a replacement guide for a Frigidaire Garage Ready Top-Freezer (model number FFHT2022AW). This replacement guide includes a complete replacement of both the freezer door handle and any involved mount pieces.
A mount replacement is only necessary should it warp to the point of no longer connecting properly to the handle.
Both the mount and the screws that attach the handle to the freezer door use the same size Phillips head screwdriver head.
    1. Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: step 1, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: step 1, image 2 of 2
      • Remove the screws keeping the handle in place on the bottom face of the freezer door with a Phillips head screwdriver.
      Ask FixBot
    2. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 2, image 1 of 3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 2, image 2 of 3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 2, image 3 of 3
      • Remove any broken pieces of the original freezer handle.
      • Pushing up on any components attached to the handle mount connected to the bottom of the handle should remove anything still connected to the freezer.
      • Use caution when handling broken components.
      Ask FixBot
    3. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 3, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 3, image 2 of 2
      • Tighten the handle mount at the top of the freezer in place if it is at all loose.
      • A bent mount may not allow the replacement handle to fully attach to the door. Replace this mount if it is missing or damaged.
      Ask FixBot
    4. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 4, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 4, image 2 of 2
      • If the securing mounts at the top or bottom of the freezer handle are damaged, they will need to be removed.
      • Unscrew the old mount by twisting counterclockwise with a Phillips head screwdriver.
      • This model has replacement screws available for purchase.
      Ask FixBot
    5. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 5, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 5, image 2 of 2
      • Screw in a new mount by twisting clockwise with a Phillips head screwdriver.
      • The handle mount needs space to properly attach to the handle. Leave some space between the flat part of the mount and the face of the freezer door.
      Ask FixBot
    6. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 6, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 6, image 2 of 2
      • Secure a replacement handle in place by locking the mount in the top of the handle.
      • The mount should slide into a plastic guide on the top of the handle on the side that faces the freezer door.
      Ask FixBot
    7. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 7, image 1 of 2 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 7, image 2 of 2
      • Align the two screw holes at the bottom of the replacement handle with the screw holes of the freezer door.
      Ask FixBot
    8. Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 8, image 1 of 3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 8, image 2 of 3 Frigidaire FFHT2022AW Freezer Door Handle Replacement: step 8, image 3 of 3
      • Secure the handle in place with two screws using a Phillips head screwdriver.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 103
All Time: 624
