Introduction
If the oven light in your Frigidaire Model FCRE3052A goes out, follow this easy guide to replace it. Most ovens use a standard 40-watt incandescent appliance bulb which is what is used here. Always check the owner's manual to ensure that the correct bulb is being used.
Unplug the oven before you begin the replacement process to ensure safety. Also, make sure that the oven is cool if it has been used recently.
Unplug the oven carefully.
Open the oven and locate the light on the upper left side at the back of the oven.
