Frigidaire CFEF3012PWC Heat Switch Repair
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
100
All Time:
871
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 - 55 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If your Frigidaire Electric Stove CFEF3012PWC has a burner that is not functioning properly, then this guide will show you how to repair the heat switch. The heat switch controls distribute power to each burner, and when this part is not functioning properly, the burner may stop working or heat unevenly. Before starting, double-check the control switch and the terminals to make sure the issue is not caused by a loose connection. If those seem to be fine, but the burner is still not working properly, then replacing the heat switch will likely fix the problem.
Important Tips:
  • Turn off the power and unplug the stove before beginning to avoid electric shock.
  • Make sure the stove and all burners have cooled completely before touching any parts.
  • Keep the user manual nearby in order to identify wiring and part locations.
Tools
    1. Frigidaire CFEF3012PWC Heat Switch Repair, Heat Switch: step 1, image 1 of 1
      • To be safe, disconnect the power at the breaker. This avoids electrical injury when working with the oven.
      Ask FixBot
    2. Frigidaire CFEF3012PWC Heat Switch Repair: step 2, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 2, image 2 of 2
      • Unplug the oven from the receptacle to be safe.
      • Move it to an open area so there is enough space to work with.
      Ask FixBot
    3. Frigidaire CFEF3012PWC Heat Switch Repair: step 3, image 1 of 1
      • Unscrew the back panel of the stove. Depending on your model, the cover may be located on the top or bottom.
      • Use a square head screwdriver.
      • If the screws are tight, use pliers to remove them.
      Ask FixBot
    4. Frigidaire CFEF3012PWC Heat Switch Repair: step 4, image 1 of 1
      • Set the multimeter to ohms. Otherwise, you may generate a short circuit if you do not have the correct setting.
      Ask FixBot
    5. Frigidaire CFEF3012PWC Heat Switch Repair: step 5, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 5, image 2 of 2
      • You must disconnect the wires to prevent electrical issues from occurring.
      • Remember where the original wires were placed. It's good to take a photo before doing so.
      Ask FixBot
    6. Frigidaire CFEF3012PWC Heat Switch Repair: step 6, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 6, image 2 of 2
      • Find the terminals on the switch. These can look different depending on whether your burner is a standard or a dual burner. Each terminal should be labeled.
      • In this case, the L1 to H1 and L2 to H2 terminals will be checked. (L=line, H=heat). Black goes on L and Red goes on H. The position may differ depending on your switch. Read the label on your switch.
      • After finding the terminals, turn the heat dial to “HI”.
      Ask FixBot
    7. Frigidaire CFEF3012PWC Heat Switch Repair: step 7, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 7, image 2 of 2
      • Check the switch for the L1 to H1 terminals
      Ask FixBot
    8. Frigidaire CFEF3012PWC Heat Switch Repair: step 8, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 8, image 2 of 2
      • Check the switch for the L2 to H2 terminals.
      Ask FixBot
    9. Frigidaire CFEF3012PWC Heat Switch Repair: step 9, image 1 of 1
      • If the multimeter does not read between 0 and 1, the switch has no durability and must be replaced.
      Ask FixBot
    10. Frigidaire CFEF3012PWC Heat Switch Repair: step 10, image 1 of 1
      • If you have a dual burner, test both sets of terminals for durability.
      • You may have other power models, but the process remains the same. If there is no connectivity, it has to be replaced.
      Ask FixBot
    11. Frigidaire CFEF3012PWC Heat Switch Repair: step 11, image 1 of 2 Frigidaire CFEF3012PWC Heat Switch Repair: step 11, image 2 of 2
      • Once the switch is confirmed to be faulty, pull the heat dial out and remove the screws that are holding the switch in place.
      Ask FixBot
    12. Frigidaire CFEF3012PWC Heat Switch Repair: step 12, image 1 of 3 Frigidaire CFEF3012PWC Heat Switch Repair: step 12, image 2 of 3 Frigidaire CFEF3012PWC Heat Switch Repair: step 12, image 3 of 3
      • Once the heat dial is removed, remove the old switch and replace with the new switch.
      • After the switch, connect the new switch to the heat dial.
      Ask FixBot
    13. Frigidaire CFEF3012PWC Heat Switch Repair: step 13, image 1 of 3 Frigidaire CFEF3012PWC Heat Switch Repair: step 13, image 2 of 3 Frigidaire CFEF3012PWC Heat Switch Repair: step 13, image 3 of 3
      • Reconnect any remaining parts that were removed earlier.
      Ask FixBot
Saad
217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 100
All Time: 871
