Introduction
Use the diagnostics or cleaning guide to test the braille cells to determine which, if any, need to be replaced or deep cleaned. Remember to check all buttons too.
Remove the 4 PH1 bolts from the bottom of the device.
The back plate is hinged at the top of the device back. Carefully rotate the back plate upwards and remove.
Note: All 4 bolts are the same size.
Note: The buttons will fall out if the device is rotated upside down.
Disconnect the battery by unplugging it.
Note: The battery is usually stuck to the motherboard with double sided tape.
Remove the 4 PH00 bolts securing the front buttons circuit board.
Remove the 2 T5 screws securing the spacebar switch.
Gently using a Size 1 Flat Head lever remove the cells from their sockets as shown to access the mainboard screws below.
Remove the 7 PH00 screws from the main circuit board.
Note: To reinstall the cells insert it back between the pins and gently push down on the connector.
Carefully lift out the main board. Be careful with the power supply daughter board which is slotted in place to the case.
Disconnect as necessary.
