Free Wheelchair Mission GEN 2 Assembly
  1. Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: step 1, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: step 1, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: step 1, image 3 of 3
    • Align the crossbar (with the hole in the center) with the screw holes on the bottom of one frame piece.
    • Attach the crossbar to the left frame piece with two [2] frame nuts and bolts.
    • Repeat on the opposite frame piece.
    Ask FixBot
  2. Free Wheelchair Mission GEN 2 Assembly: step 2, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 2, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 2, image 3 of 3
    • Align the second crossbar with the holes on the back of the frame.
    • This crossbar has two square holes on either side.
    • Attach the crossbar to the frame using four [4] frame nuts and bolts.
    Ask FixBot
  3. Free Wheelchair Mission GEN 2 Assembly: step 3, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 3, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 3, image 3 of 3
    • Align the left (L) frame piece with the brake hole on the left frame piece.
    • Insert and tighten using one [1] brake bolt.
    • Repeat using the right (R) brake with the right frame piece.
    Ask FixBot
  4. Free Wheelchair Mission GEN 2 Assembly: step 4, image 1 of 2 Free Wheelchair Mission GEN 2 Assembly: step 4, image 2 of 2
    • Slide the ring-shaped piece of one castor bearing onto the axle of one castor.
    • Slide the metal tube piece onto the axle of the castor.
    • Repeat for the second castor.
    Ask FixBot
  5. Free Wheelchair Mission GEN 2 Assembly: step 5, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 5, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 5, image 3 of 3
    • Slide another ring shaped bearing piece into the castor hole on the frame.
    • Insert the entire castor piece (castor, ring, and tube) into the opposite side of the hole.
    • Secure the castor and bearing pieces with a castor bolt.
    • Repeat on the opposite side of the frame.
    Ask FixBot
  6. Free Wheelchair Mission GEN 2 Assembly: step 6, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 6, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 6, image 3 of 3
    • Insert an axle bolt through the center of a rear wheel.
    • Insert the axle bolt with wheel into the axle hole on the frame.
    • Tighten the axle bolt.
    • Secure the wheel with a bolt on the opposite side of the hole.
    • Repeat on the opposite side of the frame to attach the other wheel.
    Ask FixBot
  7. Free Wheelchair Mission GEN 2 Assembly: step 7, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 7, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 7, image 3 of 3
    • Slide each handle into the respective slot on the top of the wheelchair.
    • Adjust the handles up or down to your desired height.
    • Secure the handles in place with one bolt and nut for each side.
    Ask FixBot
  8. Free Wheelchair Mission GEN 2 Assembly: step 8, image 1 of 2 Free Wheelchair Mission GEN 2 Assembly: step 8, image 2 of 2
    • Insert the remaining crossbar between the handles, and align the holes on both sides.
    • Secure the crossbar with four [4] blue tipped bolts and rubber tipped nuts (two on each side).
    Ask FixBot
  9. Free Wheelchair Mission GEN 2 Assembly: step 9, image 1 of 2 Free Wheelchair Mission GEN 2 Assembly: step 9, image 2 of 2
    • Orient the plastic seat with the smooth side up.
    • The rear strap can be attached to the seat in one of three positions in order to accommodate for people of different heights.
    • Loop the straps over the bars of the frame on either side.
    • Rotate the wheelchair onto its back side.
    • Secure the seat by tying each strap together.
    • Make sure that the straps are tied tightly so that the seat does not fall off the wheelchair.
    Ask FixBot
  10. Free Wheelchair Mission GEN 2 Assembly: step 10, image 1 of 2 Free Wheelchair Mission GEN 2 Assembly: step 10, image 2 of 2
    • Reorient the chair so it is upright.
    • Place the seat cushion on top of the plastic seat with the angled side in front.
    Ask FixBot
  11. Free Wheelchair Mission GEN 2 Assembly: step 11, image 1 of 1
    • Place the bottom of the backrest against the back of the seat cushion.
    • Loop each strap behind the vertical bars of the frame.
    • Secure the backrest by tying each strap together.
    • Make sure that the straps are tied tightly so that the backrest does not fall off the wheelchair.
    Ask FixBot
  12. Free Wheelchair Mission GEN 2 Assembly: step 12, image 1 of 3 Free Wheelchair Mission GEN 2 Assembly: step 12, image 2 of 3 Free Wheelchair Mission GEN 2 Assembly: step 12, image 3 of 3
    • Slide a footrest socket over the rail located near the front of the seat.
    • Insert a footrest through the bottom of the footrest socket.
    • Secure the footrest with a bolt above and below the socket.
    • Adjust the footrest socket to your desired height.
    • Align the socket's bolt with the nearest hole in the rail, and tighten the bolt.
    • Repeat this step on the opposite rail.
    Ask FixBot
  13. Free Wheelchair Mission GEN 2 Assembly: step 13, image 1 of 1
    Ask FixBot
  14. Free Wheelchair Mission GEN 2 Assembly: step 14, image 1 of 1
    • Insert the pump bracket through the lower crossbar.
    • Secure the bracket with a rubber tipped nut.
    • Place the tire pump in the bracket.
    Ask FixBot
To disasemble your device, follow these instructions in reverse order.
3 other people completed this guide.
Garrett Goff
194 Reputation
1 Guide authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 57
All Time: 1,810
