Up to 20% off select tools
Framework Laptop Input Cover Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
101
All Time:
2,627
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Parts
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
    Optional
Introduction
Go to step 1 ↓
Use this guide to replace the Input Cover on your Framework laptop.
You'll only need a T5 bit screwdriver and a replacement Input Cover for this guide. Note: The Framework laptop comes with a screwdriver with a T5 bit and a spudger.
    1. Framework Laptop Input Cover Replacement, Shut Down and Unplug the Framework Laptop: step 1, image 1 of 1
      • Shut down the laptop and unplug the power cable if it is plugged in.
      • The light around the fingerprint reader will turn off when the laptop has powered down.
      Ask FixBot
    2. Framework Laptop Input Cover Replacement, Unscrew the Screws on the Bottom Cover: step 2, image 1 of 1
      • Close the laptop lid and place it upside down.
      • Locate the five T5 bits underneath the laptop. Using a screwdriver with a T5 bit, unscrew the five screws on the bottom cover.
      • The laptop comes with a screwdriver with a T5 bit. This screwdriver will work for this guide.
      • These screws will remain attached to the bottom cover even when fully unscrewed. Do not attempt to remove them.
      • The screw on the bottom left will not unscrew as far. This screw lifts the input cover slightly.
      • This screw will make a clicking noise when it has been unscrewed far enough.
      Ask FixBot
    3. Framework Laptop Input Cover Replacement, Detach the Input Cover: step 3, image 1 of 2 Framework Laptop Input Cover Replacement, Detach the Input Cover: step 3, image 2 of 2
      • Flip the laptop over and open the lid.
      • Be careful while removing the input cover! It is still attached to the mainboard by the touchpad cable. This cable can be left attached for now.
      • The bottom right corner of the input cover should have lifted up to reveal a small gap which can be used to remove the input cover.
      • Carefully lift the input cover up from the bottom right corner using your finger or a pry tool. The input cover should be only held in place with magnets.
      • Avoid using excessive force which may damage the touchpad cable.
      • If the LED lights on the left and right sides of the case flash red after removing the cover, the system is still powered on. Ensure the laptop is powered off and is unplugged. Check that the LEDs have turned off before continuing.
      Ask FixBot
    4. Framework Laptop Input Cover Replacement, Detach the Touchpad Cable: step 4, image 1 of 2 Framework Laptop Input Cover Replacement, Detach the Touchpad Cable: step 4, image 2 of 2
      • Locate the large black cable on the right side connecting the touchpad to the mainboard.
      • On the mainboard side of the cable, there is a large loop with a orange spot. Insert your finger through the loop and pull up.
      • It is not recommended to remove the touchpad cable from the touchpad side unless the touchpad or touchpad cable is being replaced, as this side is more fragile.
      • There should be little resistance when removing the cable. Avoid excessive force which may damage the cable.
      • You can now safely remove the input cover from the laptop.
      • During reassembly:
      • Remember to connect the new touchpad cable to the mainboard before placing the new input cover on the laptop.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Framework Laptop 13 answers community for help.
3 other people completed this guide.
Author
with
Sam
469 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 101
All Time: 2,627
