OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Follow this guide to replace or upgrade the SSD in your Framework Laptop 13.
Your Framework Laptop uses a M.2 2280 NVMe SSD (Solid State Drive) for storage.
Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
Flip over your laptop and open it.
Use your fingers to lift the Input Cover up and release it from its magnets.
Flip the top of the Input Cover so the Keyboard is facing down.
Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
Insert your finger into the Touchpad Cable press connector loop.
Lift up to disconnect the Touchpad Cable from the Mainboard.
Use your Framework Screwdriver to remove the 3.0 mm‑long T5 Torx screw securing the SSD.
Grip the end of the SSD with the screw hole and slide it out of its socket.
Remove the SSD.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
Before continuing, check the Touchpad Cable's ZIF connector located on the back of the Touchpad:
Make sure the white line on the cable is parallel to and adjacent with the socket.
If the cable isn't inserted far enough, use the flat end of the Framework Screwdriver to flip up the black latch, reposition the cable, and lock the latch.
Position the Input Cover, Keyboard down, on top of the laptop so it just covers the battery.
Align the press connector over its socket and press down with your finger.
Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
