Introduction
Use this guide to replace or upgrade the Mainboard in your Framework Laptop 13 Pro.
The Mainboard (aka motherboard) is responsible for the primary functions for your laptop. If you want to upgrade your processor, you'll need to replace the Mainboard.
Replacement Mainboards come with a pre-installed heatsink but don't come with pre-installed storage, memory, or Wi-Fi modules. This guide will show how to transfer them to your new Mainboard.
If you're running Windows:
- Make sure you back up your data.
- If you’re running a Pro version of Windows, follow these directions to suspend BitLocker.
- If you're running a Home version of Windows and have enabled Windows Device Encryption, you'll want to disable it. To disable it, press Win + I to open Settings and select Privacy & Security. Then, click on Device Encryption on the right panel and toggle the setting to Off.
- Find your product key or link your Windows license to a Microsoft account to make sure you can re‑activate Windows after the change.
Use your finger to flip the Expansion Card latches into the unlocked position.
Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
Flip over your laptop and open it.
Use your fingers to lift the Input Cover up and release it from its magnets.
Flip the top of the Input Cover so the Keyboard is facing down.
Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
Insert your finger into the Touchpad Cable press connector loop.
Lift up to disconnect the Touchpad Cable from the Mainboard.
Use your fingers to grip the edges of the Battery connector and slide it straight out of its socket to disconnect the Battery.
Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it.
Make sure there's no dust or debris on top of the Interposer before continuing.
Use your Framework Screwdriver to remove the 3.0 mm‑long T5 Torx screw securing the SSD.
Grip the end of the SSD with the screw hole and slide it out of its socket.
Remove the SSD.
Use your fingers to grip the edges of the Speakers Cable connector.
Pull the connector straight out of its socket to disconnect it.
Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Audio Board ZIF connector on the Mainboard.
Grip the Display eDP Cable connector by its pull tab and lift up to disconnect it.
Use your fingers or the flat end of the Framework Screwdriver to lift the two Antenna Cables out of their clips on the Mainboard.
Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module.
Grip the end of the Wi-Fi module with the screw hole and slide it out of its socket.
Position the Wi-Fi module to the right of the laptop to keep it out of the way of the Mainboard.
Use your Framework Screwdriver to remove the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
Use your fingers to lift the bottom edge of the Mainboard enough to grip its edges.
Lift the Mainboard off its alignment pegs and remove it.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Grab the Mainboard by its edges and place it into the laptop and onto its alignment pegs.
Use your Framework Screwdriver to install the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
Press the Webcam Cable connector straight down into its socket to connect it.
Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
Hold the Wi-Fi module down with your finger.
Position the black antenna cable connector over the left Wi-Fi module's coaxial socket.
Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
Repeat the procedure with the white antenna cable.
Use your Framework Screwdriver to tighten the captive T5 Torx screw securing the Wi-Fi module.
Use the flat end of your Framework Screwdriver to press the two Antenna Cables into their clips on the Mainboard.
Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
Remove the LPCAMM2 Memory Spacer and recycle it.
Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
Before continuing, check the pins on the Battery socket and make sure they aren't bent.
Use your fingers to align the Battery connector with its socket and slide it straight in to reconnect the Battery.
Position the Input Cover, keyboard down, on top of the laptop so it just covers the Battery.
Align the press connector over its socket and press down with your finger.
Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
Slide an Expansion Card into an Expansion Card slot.
Repeat for the remaining Expansion Cards.
You finished fixing your Framework Laptop! To update to the latest drivers, firmware, and software to ensure the full functionality, check out this page.
The first boot will take longer and start with a “Memory Training in Progress” screen. If you run into any errors during Memory Training, please see this page.
If you need help, contact Framework support.
