OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Follow this guide to remove and replace the LPCAMM2 memory (aka RAM) in your Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3).
Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3) supports one slot of LPCAMM2 memory up to 96GB at the native 7467 MT/s speed. It is compatible with LPCAMM2 modules with memory speed rated above 7467 MT/s, but the speed will be capped at 7467 MT/s because of the platform limitation.
Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
Flip over your laptop and open it.
Use your fingers to lift the Input Cover up and release it from its magnets.
Flip the top of the Input Cover so the Keyboard is facing down.
Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
Insert your finger into the Touchpad Cable press connector loop.
Lift up to disconnect the Touchpad Cable from the Mainboard.
Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it.
Make sure there's no dust or debris on top of the Interposer before continuing.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
Align the press connector over its socket and press down with your finger.
Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
You finished fixing your Framework Laptop! The first boot will take longer and start with a “Memory Training in Progress” screen. If you run into any errors during Memory Training, please see this page.
If you need help, contact Framework support.
