Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Before you begin: step 1, image 2 of 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Loosen the Input Cover screws: step 2, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Loosen the Input Cover screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Lift the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Lift the Input Cover: step 3, image 2 of 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      Ask FixBot
    3. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Flip over the Input Cover: step 4, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Flip over the Input Cover: step 4, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Disconnect the Touchpad Cable: step 5, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Disconnect the Touchpad Cable: step 5, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the Input Cover: step 6, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the Input Cover: step 6, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Loosen the LPCAMM2 Memory Cover: step 7, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Loosen the LPCAMM2 Memory Cover: step 7, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screws securing the LPCAMM2 Memory Cover in reverse order from 3–1.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory Cover: step 8, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory Cover: step 8, image 2 of 2
      • Lift the LPCAMM2 Memory Cover straight off the memory and remove it.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory: step 9, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory: step 9, image 2 of 2
      • Grip the LPCAMM2 module by its edges and lift it straight off its alignment pegs to remove it.
      • Avoid touching the Interposer below the module. If the Interposer accidentally shifts, grab it by its edges to place it back into its alignment pegs.
      • Make sure there's no dust or debris on top of the Interposer before continuing.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory Interposer: step 10, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory Interposer: step 10, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Remove the LPCAMM2 Memory Interposer: step 10, image 3 of 3
      • Be extremely careful when handling the Interposer, as its pins can break easily. Only grip its edges to avoid touching its pins.
      • Use a fingernail to lift up the bottom edge of the Interposer until you can grip its edges with your fingers.
      • Lift the Interposer straight off its alignment pegs and remove it.
      • Avoid pressing or bending the pins against the Mainboard as you lift.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Disassembly complete: step 11, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory Interposer: step 12, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory Interposer: step 12, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory Interposer: step 12, image 3 of 3
      • The Interposer only slots in the Mainboard one way. Use the holes in the Mainboard and the pegs in the Interposer to help orient it. The notch in the Interposer should be at the bottom left corner.
      • Place the Interposer onto the Mainboard, making sure it slots in properly and that it sits flat surrounded by four sponges.
      • You may have to lightly bend the orange Webcam Cable connector tab to keep it out of the way.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory: step 13, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory: step 13, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory: step 13, image 3 of 3
      • Place the LPCAMM2 module on top of the Interposer, making sure it slots into its alignment pegs.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory Cover: step 14, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the LPCAMM2 Memory Cover: step 14, image 2 of 2
      • Place the LPCAMM2 Memory Cover on top of the memory, making sure its screws align with the screw holes.
      • The cover should lay flat when aligned properly.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Tighten the LPCAMM2 Memory Cover: step 15, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Tighten the LPCAMM2 Memory Cover: step 15, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screws securing the LPCAMM2 Memory Cover in order from 1–3.
      • Make sure the screws are snug enough to create proper contact between the memory and the Mainboard.
      Ask FixBot
    1. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Position the Input Cover: step 16, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Position the Input Cover: step 16, image 2 of 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    2. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Connect the Touchpad Cable: step 17, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Connect the Touchpad Cable: step 17, image 2 of 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
      Ask FixBot
    3. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the Input Cover: step 18, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Place the Input Cover: step 18, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    4. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement: step 19, image 1 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement: step 19, image 2 of 3 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement: step 19, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    5. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Reposition the laptop: step 20, image 1 of 1
      • Close the laptop and flip it over.
      Ask FixBot
    6. Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Tighten the Input Cover screws: step 21, image 1 of 2 Framework Laptop 13 Pro LPCAMM2 Memory Interposer Replacement, Tighten the Input Cover screws: step 21, image 2 of 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
You finished fixing your Framework Laptop! The first boot will take longer and start with a “Memory Training in Progress” screen. If you run into any errors during Memory Training, please see this page.
If you need help, contact Framework support.
Alex Diaz-Kokaisl
248,468 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 35
Past 30 Days: 89
All Time: 218
