Framework Laptop 13 Pro Bottom Cover Upgrade Kit
View statistics:
Past 24 Hours:
2
Past 7 Days:
40
Past 30 Days:
140
All Time:
453
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to upgrade your Framework Laptop 13 to the Framework Laptop 13 Pro Bottom Cover, Battery, Speakers, Audio Board and Haptic Touchpad.
You can't mix and match the aforementioned parts from across the 13 and 13 Pro lineup. Each part within the Bottom Cover (minus the Mainboard) needs to be replaced. For detailed parts compatibility, click here.
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Before you begin: step 1, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Before you begin: step 1, image 2 of 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Expansion Cards: step 2, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Expansion Cards: step 2, image 2 of 2
      • While pressing down the release button, grip the lip of the Expansion Card and pull it out of its slot to release it.
      • This might take some initial force. If you're having trouble, make sure you're fully pressing down the release button.
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 3, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 3, image 2 of 2
      • Slide the Expansion Card out of its slot and remove it.
      • Remove the remaining Expansion Cards.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Input Cover screws: step 4, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Input Cover screws: step 4, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      • The screw will make an audible "clicking" sound once it's fully loosened.
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Input Cover: step 5, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Input Cover: step 5, image 2 of 2
      • Flip over the laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      Ask FixBot
    3. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Flip over the Input Cover: step 6, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Flip over the Input Cover: step 6, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Touchpad Cable: step 7, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Touchpad Cable: step 7, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Input Cover: step 8, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Input Cover: step 8, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Battery: step 9, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Battery: step 9, image 2 of 2
      • When disconnecting the Battery, make sure you slide its connector straight out of its socket or else you risk bending the socket's pins.
      • Use your fingers to grip the edges of the Battery connector and slide it straight out of its socket to disconnect the Battery.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Speakers: step 10, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Speakers: step 10, image 2 of 2
      • Use your fingers to grip the edges of the Speaker cable connector.
      • Pull the connector straight out of its socket to disconnect it.
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Audio Board: step 11, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Audio Board: step 11, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Audio Board ZIF connector on the Mainboard.
      Ask FixBot
    3. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 12, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 12, image 2 of 2
      • Use your fingers to lightly grip the Audio Board cable and slide it straight out of its socket.
      Ask FixBot
    4. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the grounding tape: step 13, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the grounding tape: step 13, image 2 of 2
      • Use the flat end of your Framework Screwdriver to peel off the grounding tape on the left Hinge.
      Ask FixBot
    5. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Display eDP Cable: step 14, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Display eDP Cable: step 14, image 2 of 2
      • Grip the Display eDP Cable connector by its pull tab and lift up to disconnect it.
      Ask FixBot
    6. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Display eDP Cable: step 15, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Display eDP Cable: step 15, image 2 of 2
      • Lift the Display eDP Cable out of its slot in the Bottom Cover.
      Ask FixBot
    7. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Webcam Cable: step 16, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Webcam Cable: step 16, image 2 of 2
      • Grip the Webcam Cable connector by its pull tab and lift up to disconnect it.
      Ask FixBot
    8. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Antenna Cables: step 17, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Antenna Cables: step 17, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Lift the Antenna Cables: step 17, image 3 of 3
      • Use your fingers or the flat end of the Framework Screwdriver to lift the two Antenna Cables out of their clips on the Mainboard.
      Ask FixBot
    9. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Wi-Fi module screw: step 18, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Wi-Fi module screw: step 18, image 2 of 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module.
      • The module might pop up at a shallow angle when you loosen the screw.
      Ask FixBot
    10. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Wi-Fi module: step 19, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Wi-Fi module: step 19, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Disconnect the Wi-Fi module: step 19, image 3 of 3
      • Grip the end of the Wi-Fi module with the screw hole and slide it out of its socket.
      • Don't pull the module too far from its socket, as it's still connected by two cables.
      • Keep the plastic bracket attached to the module to prevent the cables from disconnecting.
      • Position the Wi-Fi module to the right of the laptop to keep it out of the way of the Mainboard.
      Ask FixBot
    11. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Mainboard screws: step 20, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Mainboard screws: step 20, image 2 of 2
      • Use your Framework Screwdriver to remove the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
      • Since these screws aren't captive, put them in a safe place.
      Ask FixBot
    12. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Mainboard: step 21, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Mainboard: step 21, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Mainboard: step 21, image 3 of 3
      • Use your fingers to lift the bottom edge of the Mainboard enough to grip its edges.
      • Lift the Mainboard off its alignment pegs and remove it.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Hinge screws: step 22, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Hinge screws: step 22, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Hinge screws: step 22, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to remove two 4.0 mm‑long T5 Torx screws on each Hinge connected to the Bottom Cover (four total).
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Top Cover: step 23, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the Top Cover: step 23, image 2 of 2
      • Lift the Top Cover off its two sets of alignment pegs on the Bottom Cover and remove it.
      Ask FixBot
    1. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Unbox your Bottom Cover Upgrade Kit: step 24, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Unbox your Bottom Cover Upgrade Kit: step 24, image 2 of 2
      • Unbox your Bottom Cover Upgrade Kit and make sure you've received the following items:
      • Bottom Cover Kit
      • Keyboard
      • Input Cover Frame (including the Keyboard Bracket and Fingerprint Reader Cable)
      • Speaker Kit
      • Battery
      • Audio Board Kit
      • Fastener Kit – Input Cover and Keyboard (only the Keyboard and Keyboard Bracket screws are needed—the rest can be kept as spares)
      Ask FixBot
    2. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the Speakers: step 25, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the Speakers: step 25, image 2 of 2
      • Separate the Speakers from each other if they're attached.
      Ask FixBot
    3. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Speakers: step 26, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Speakers: step 26, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Speakers: step 26, image 3 of 3
      • Place the left Speaker into its slot on the Bottom Cover, making sure it's aligned with its screw posts and threaded through its alignment peg.
      • The left Speaker has an "L" labeled on it.
      Ask FixBot
    4. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 27, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 27, image 2 of 2
      • Repeat the previous step for the right Speaker.
      • The right Speaker has an "R" labeled on it.
      Ask FixBot
    5. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Speaker screws: step 28, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Speaker screws: step 28, image 2 of 2
      • Use your Framework Screwdriver to tighten the two T5 Torx screws on each Speaker (4 total).
      Ask FixBot
    6. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Route the Speaker Cables: step 29, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Route the Speaker Cables: step 29, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Route the Speaker Cables: step 29, image 3 of 3
      • Starting from the right Speaker, press the speaker cable into its metal and plastic clips on the Bottom Cover.
      • Pull the cable taut against the Bottom Cover as you do this, as you'll need slack along the left edge.
      Ask FixBot
    7. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 30, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 30, image 2 of 2
      • If you're having difficulty pressing the speaker cable into its plastic clips, twist the cable so it's vertical and use the flat end of your Framework Screwdriver to press it down.
      Ask FixBot
    8. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 31, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 31, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 31, image 3 of 3
      • Repeat the previous two steps for the section of Speaker Cable near the left Speaker.
      Ask FixBot
    9. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the liner: step 32, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the liner: step 32, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the liner: step 32, image 3 of 3
      • Remove the blue liner from the black tape near the left Speaker.
      Ask FixBot
    10. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the tape: step 33, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the tape: step 33, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Separate the tape: step 33, image 3 of 3
      • Slide the flat end of your Framework Screwdriver under the black tape and separate one of its long edges from the Chassis.
      Ask FixBot
    11. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Adhere the Speaker Cable: step 34, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Adhere the Speaker Cable: step 34, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Adhere the Speaker Cable: step 34, image 3 of 3
      • While holding the tape out of the way, lay the Speaker Cable into the channel underneath it.
      • Press the tape over the Speaker Cable to adhere it to the Chassis.
      Ask FixBot
    12. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Check the Battery socket: step 35, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Check the Battery socket: step 35, image 2 of 2
      • Before continuing, check the pins on the Battery socket and make sure they aren't bent.
      • If any of the pins are bent, reach out to Framework Support.
      Ask FixBot
    13. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Mainboard: step 36, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Mainboard: step 36, image 2 of 2
      • Grab the Mainboard by its edges and place it into the Bottom Cover and onto its alignment pegs.
      Ask FixBot
    14. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Mainboard screws: step 37, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Mainboard screws: step 37, image 2 of 2
      • Use your Framework Screwdriver to install the five 1.5 mm‑long T5 Torx screws securing the Mainboard.
      Ask FixBot
    15. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Insert the Audio Board: step 38, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Insert the Audio Board: step 38, image 2 of 2
      • Angle the left edge of the Audio Board downward and slide the headphone jack through its hole in the Bottom Cover.
      • Align the screw hole in the Audio Board with its post and press it flat to the Bottom Cover.
      Ask FixBot
    16. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Audio Board screw: step 39, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Audio Board screw: step 39, image 2 of 2
      • Use your Framework Screwdriver to install the 3.0 mm‑long T5 Torx screw securing the Audio Board.
      Ask FixBot
    17. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 40, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 40, image 2 of 2
      • Insert the Battery into its cutout, making sure its plastic tabs are slotted into the Bottom Cover.
      Ask FixBot
    18. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Battery screws: step 41, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Battery screws: step 41, image 2 of 2
      • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the Battery.
      Ask FixBot
    19. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Top Cover: step 42, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Top Cover: step 42, image 2 of 2
      • Place the Top Cover on its two sets of alignment pegs on the Bottom Cover.
      • Make sure all of the cables are above the Bottom Cover before continuing.
      Ask FixBot
    20. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Hinge screws: step 43, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Hinge screws: step 43, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Hinge screws: step 43, image 3 of 3
      • While supporting the Top Cover with one hand, use your Framework Screwdriver to install two 4.0 mm‑long T5 Torx screws on each Hinge connected to the Bottom Cover (four total).
      Ask FixBot
    21. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Display eDP Cable: step 44, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Display eDP Cable: step 44, image 2 of 2
      • Place the Display eDP Cable into its slot on the Bottom Cover.
      Ask FixBot
    22. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Display eDP Cable: step 45, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Display eDP Cable: step 45, image 2 of 2
      • Press the Display eDP Cable connector straight down into its socket to connect it.
      Ask FixBot
    23. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Adhere the grounding tape: step 46, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Adhere the grounding tape: step 46, image 2 of 2
      • Press the grounding tape onto the left Hinge to adhere it.
      Ask FixBot
    24. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Audio Board: step 47, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Audio Board: step 47, image 2 of 2
      • Slide the Audio Board cable straight into its socket.
      Ask FixBot
    25. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 48, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 48, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Audio Board ZIF connector.
      Ask FixBot
    26. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Speakers: step 49, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Speakers: step 49, image 2 of 2
      • Slide the Speaker connector straight into its socket.
      Ask FixBot
    27. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Webcam Cable: step 50, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Webcam Cable: step 50, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Webcam Cable: step 50, image 3 of 3
      • Use your finger to guide the Webcam Cable into its metal pegs on the Bottom Cover.
      • Refer to this photo for how the cable should look when properly routed.
      Ask FixBot
    28. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Webcam Cable: step 51, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Webcam Cable: step 51, image 2 of 2
      • Press the Webcam Cable connector straight down into its socket to connect it.
      Ask FixBot
    29. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 52, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 52, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 52, image 3 of 3
      • Use your finger to press the Antenna Cables into their metal clip on the Bottom Cover.
      • Rotate the cables around the raised corner at the top right of the Mainboard so they point towards the Wi-Fi module.
      • Refer to this photo for how the cables should look when properly routed.
      Ask FixBot
    30. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Wi-Fi module cover screw: step 53, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Loosen the Wi-Fi module cover screw: step 53, image 2 of 2
      • The Bottom Cover comes with a pre-installed Wi-Fi Module cover. It's optional to swap your cover with this replacement.
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module cover.
      Ask FixBot
    31. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Remove the cover: step 54, image 1 of 1
      • Remove the Wi-Fi module cover.
      Ask FixBot
    32. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Wi-Fi module: step 55, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Wi-Fi module: step 55, image 2 of 2
      • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    33. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reconnect the Wi-Fi module: step 56, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reconnect the Wi-Fi module: step 56, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reconnect the Wi-Fi module: step 56, image 3 of 3
      • If the Antenna Cables got accidentally disconnected, follow this step to reconnect them. Otherwise, skip this step to continue the guide normally.
      • Hold the Wi-Fi module down with your finger.
      • Position the black antenna cable connector over the Wi-Fi module's coaxial socket indicated by the black arrow.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      Ask FixBot
    34. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Wi-Fi module screw: step 57, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Wi-Fi module screw: step 57, image 2 of 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing the Wi-Fi module.
      Ask FixBot
    35. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 58, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 58, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reroute the Antenna Cables: step 58, image 3 of 3
      • Use the flat end of your Framework Screwdriver to press the two Antenna Cables into their rubber clips on the Mainboard.
      Ask FixBot
    36. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reconnect the Battery: step 59, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Reconnect the Battery: step 59, image 2 of 2
      • Use your fingers to align the Battery connector with its socket and slide it straight in to reconnect the Battery.
      Ask FixBot
    37. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Keyboard: step 60, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Keyboard: step 60, image 2 of 2
      • Place the Keyboard into its cutout in the Top Cover.
      Ask FixBot
    38. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Keyboard screws: step 61, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Keyboard screws: step 61, image 2 of 2
      • Use your Framework Screwdriver to install the forty-six 1.2 mm‑long black PH0 screws securing the Keyboard.
      • The screw holes for the Keyboard are labeled with "KB" and an arrow pointing to them.
      Ask FixBot
    39. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Keyboard Bracket: step 62, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Keyboard Bracket: step 62, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Keyboard Bracket: step 62, image 3 of 3
      • Place the Keyboard Bracket onto its alignment pegs.
      Ask FixBot
    40. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Keyboard Bracket screws: step 63, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Keyboard Bracket screws: step 63, image 2 of 2
      • Use your Framework Screwdriver to install the twenty 1.3 mm‑long silver PH0 screws securing the Keyboard Bracket.
      Ask FixBot
    41. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Unlock the Fingerprint Reader: step 64, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Unlock the Fingerprint Reader: step 64, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Fingerprint Reader ZIF connector located on the Fingerprint Reader board.
      Ask FixBot
    42. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Fingerprint Reader Cable: step 65, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Fingerprint Reader Cable: step 65, image 2 of 2
      • Slide the Fingerprint Reader Cable straight into its socket.
      Ask FixBot
    43. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 66, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 66, image 2 of 2
      • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Fingerprint Reader ZIF connector.
      Ask FixBot
    44. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 67, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 67, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 67, image 3 of 3
      • Repeat the previous three steps to connect the Fingerprint Reader Cable on the Hub Board.
      Ask FixBot
    45. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Position the Input Cover: step 68, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Position the Input Cover: step 68, image 2 of 2
      • Your old Input Cover is not compatible—only use the new one.
      • Position the Input Cover, keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    46. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Touchpad Cable: step 69, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Connect the Touchpad Cable: step 69, image 2 of 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    47. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Input Cover: step 70, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Place the Input Cover: step 70, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    48. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 71, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 71, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 71, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    49. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Input Cover screws: step 72, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Tighten the Input Cover screws: step 72, image 2 of 2
      • Close the laptop and flip it over.
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
    50. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Expansion Cards: step 73, image 1 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Expansion Cards: step 73, image 2 of 3 Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Install the Expansion Cards: step 73, image 3 of 3
      • For Expansion Card compatibility, check here.
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      • Repeat for the remaining Expansion Cards.
      Ask FixBot
    51. Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 74, image 1 of 2 Framework Laptop 13 Pro Bottom Cover Upgrade Kit: step 74, image 2 of 2
      • Use your finger to flip both latches and lock the rows of Expansion Cards.
      Ask FixBot
    52. Framework Laptop 13 Pro Bottom Cover Upgrade Kit, Update the software: step 75, image 1 of 1
      • You've finished upgrading your Framework Laptop! Check out this page to update to the latest drivers, firmware, and software.
      • You'll need to update to the latest BIOS for the battery to reach full capacity.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
251,225 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 140
All Time: 453
