Up to 20% off select tools
Framework Laptop 13 Memory Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
135
All Time:
648
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the memory (aka RAM) in your Framework Laptop 13.
Your Framework Laptop has two DDR5 SO-DIMM sockets that supports up to 48 GB each of DDR5-5600 memory. If you install memory faster than the supported speed, the laptop will work properly, but not use the full memory speed.
For a list of validated AMD Ryzen™ AI 300 Series memory modules, check out this link.
For a list of validated AMD Ryzen™ 7040 Series memory modules, check out this link.
    1. Framework Laptop 13 Memory Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 13 Memory Replacement, Before you begin: step 1, image 2 of 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Ask FixBot
    1. Framework Laptop 13 Memory Replacement, Loosen the Input Cover screws: step 2, image 1 of 2 Framework Laptop 13 Memory Replacement, Loosen the Input Cover screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      • The screw will make an audible "clicking" sound once it's fully loosened.
      Ask FixBot
    2. Framework Laptop 13 Memory Replacement, Lift the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Memory Replacement, Lift the Input Cover: step 3, image 2 of 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      Ask FixBot
    3. Framework Laptop 13 Memory Replacement, Flip over the Input Cover: step 4, image 1 of 2 Framework Laptop 13 Memory Replacement, Flip over the Input Cover: step 4, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Memory Replacement, Disconnect the Touchpad Cable: step 5, image 1 of 2 Framework Laptop 13 Memory Replacement, Disconnect the Touchpad Cable: step 5, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Memory Replacement, Remove the Input Cover: step 6, image 1 of 2 Framework Laptop 13 Memory Replacement, Remove the Input Cover: step 6, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 13 Memory Replacement, Remove the memory: step 7, image 1 of 3 Framework Laptop 13 Memory Replacement, Remove the memory: step 7, image 2 of 3 Framework Laptop 13 Memory Replacement, Remove the memory: step 7, image 3 of 3
      • Depending on your Mainboard's generation, you might not have black flaps covering your memory.
      • While holding up the black flap covering the left memory module, push the two metal arms on each side of the module outward until they disengage and the module pops up at a shallow angle.
      • Slide the memory module out of its socket and remove it.
      Ask FixBot
    2. Framework Laptop 13 Memory Replacement: step 8, image 1 of 3 Framework Laptop 13 Memory Replacement: step 8, image 2 of 3 Framework Laptop 13 Memory Replacement: step 8, image 3 of 3
      • Repeat the previous step for the right module.
      Ask FixBot
    1. Framework Laptop 13 Memory Replacement, Disassembly complete: step 9, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 13 Memory Replacement, Install the left memory: step 10, image 1 of 3 Framework Laptop 13 Memory Replacement, Install the left memory: step 10, image 2 of 3 Framework Laptop 13 Memory Replacement, Install the left memory: step 10, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • While holding up the black flap covering the left memory module, orient the module with its label facing down and align the gold contacts with the left socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 13 Memory Replacement, Install the right memory: step 11, image 1 of 3 Framework Laptop 13 Memory Replacement, Install the right memory: step 11, image 2 of 3 Framework Laptop 13 Memory Replacement, Install the right memory: step 11, image 3 of 3
      • Repeat the previous step for the right socket, except orient the module so its label is facing upward.
      Ask FixBot
    1. Framework Laptop 13 Memory Replacement, Check the Touchpad Cable: step 12, image 1 of 3 Framework Laptop 13 Memory Replacement, Check the Touchpad Cable: step 12, image 2 of 3 Framework Laptop 13 Memory Replacement, Check the Touchpad Cable: step 12, image 3 of 3
      • Before continuing, check the Touchpad Cable's ZIF connector located on the back of the Touchpad:
      • Make sure the white line on the cable is parallel to and adjacent with the socket.
      • If the cable isn't inserted far enough, use the flat end of the Framework Screwdriver to flip up the black latch, reposition the cable, and lock the latch.
      Ask FixBot
    2. Framework Laptop 13 Memory Replacement, Position the Input Cover: step 13, image 1 of 2 Framework Laptop 13 Memory Replacement, Position the Input Cover: step 13, image 2 of 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    3. Framework Laptop 13 Memory Replacement, Connect the Touchpad Cable: step 14, image 1 of 2 Framework Laptop 13 Memory Replacement, Connect the Touchpad Cable: step 14, image 2 of 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    4. Framework Laptop 13 Memory Replacement, Place the Input Cover: step 15, image 1 of 2 Framework Laptop 13 Memory Replacement, Place the Input Cover: step 15, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    5. Framework Laptop 13 Memory Replacement: step 16, image 1 of 3 Framework Laptop 13 Memory Replacement: step 16, image 2 of 3 Framework Laptop 13 Memory Replacement: step 16, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    6. Framework Laptop 13 Memory Replacement, Tighten the Input Cover screws: step 17, image 1 of 2 Framework Laptop 13 Memory Replacement, Tighten the Input Cover screws: step 17, image 2 of 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
You finished fixing your Framework Laptop!
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
If you need help, contact Framework support.
Alex Diaz-Kokaisl
253,211 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 135
All Time: 648
