OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Follow this guide to remove and replace the speakers in your Framework Laptop 12.
The speakers are replaced in a pair. If you're not getting any sound or your audio sounds distorted, you may need to replace your speakers.
You'll encounter some component terms in this guide:
- The Input Cover is the part that contains the keyboard and trackpad.
Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
Open the laptop lid so that both the screen and the base lie flat on your work surface.
Use your fingers to grip the Input Cover in the hinge cutouts.
Lift upwards to swing the Input Cover up from the base of the laptop.
Remove the Input Cover.
Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board, located near the left edge of the laptop.
Use the flat end of your Framework Screwdriver to pry up the speaker connector from its recess near the top of the left speaker.
Use your Framework Screwdriver to loosen the four captive T5 Torx screws (two per speaker) securing the speakers.
Use your Framework Screwdriver to lift and guide the wire connecting the two speakers out of the frame channel.
Use your Framework Screwdriver to lift the silver tape securing the center of the speaker wire to the frame.
Use your Framework Screwdriver to loosely screw the left speaker in place.
Starting near the left speaker, use your fingers and your Framework Screwdriver to carefully press and guide the speaker wire back into its channel.
Zoom in on the second image to see how the wire sits in its channel.
Press the silver tape to adhere the center of the wire to the frame.
Angle the bottom edge of the Input Cover towards the base of the laptop.
Align and insert the bottom edge of the Input Cover into the base of the laptop.
Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
Close the laptop lid.
Flip your laptop face-down on a clean work surface.
Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
