Up to 20% off select tools
Framework Laptop 12 Pre-built Quick Start Guide
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
79
All Time:
759
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Very easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Congratulations on getting the Framework Laptop 12 Pre-built Edition! Follow this quick start guide to get your laptop set up and running in just a few minutes.
If you got the Framework Laptop DIY Edition, follow this quick start guide instead.
    1. Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: step 1, image 1 of 2 Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: step 1, image 2 of 2
      • Unbox your Framework Laptop and make sure you've received all the items:
      • Framework Laptop 12
      • Framework Screwdriver
      • Expansion Cards you selected during purchase
      • Framework Power Adapter, USB-C Cable, and AC Cable
      Ask FixBot
    2. Framework Laptop 12 Pre-built Quick Start Guide, Set your laptop on a clean surface: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: step 3, image 1 of 3 Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: step 3, image 2 of 3 Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: step 3, image 3 of 3
      • Slide an Expansion Card into the Expansion Card slot.
      • All official Expansion Cards work fully in all slots, so you can install them however you wish!
      • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click in place, and the front edge should be flush with the laptop.
      • Repeat the procedure with the remaining expansion cards.
      Ask FixBot
    4. Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: step 4, image 1 of 2 Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: step 4, image 2 of 2
      • If there's a red bar showing under each Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots help keep the cards in place when you unplug cables from them.
      Ask FixBot
    5. Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: step 5, image 1 of 3 Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: step 5, image 2 of 3 Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: step 5, image 3 of 3
      • Plug the AC Cable into the Power Adapter.
      • Plug the USB-C Cable into the Power Adapter.
      • You can plug either end of the USB-C cable into the adapter.
      • Plug the AC Cable into a power outlet.
      Ask FixBot
    6. Framework Laptop 12 Pre-built Quick Start Guide, Plug in the laptop: step 6, image 1 of 1
      • Your Framework Laptop ships in shipping mode, where the battery is disabled until you plug the laptop in for the first time.
      • Plug the USB-C cable into any USB-C port on your laptop.
      Ask FixBot
    7. Framework Laptop 12 Pre-built Quick Start Guide, Turn on the laptop: step 7, image 1 of 1
      • Your Framework Laptop is ready for use! Open the lid and press the power button along the right edge of the laptop.
      Ask FixBot
For drivers, firmware, and software updates, check out this page.
If you need help, contact Framework support.
Arthur Shi
354,406 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 79
All Time: 759
