Up to 20% off select tools
Framework Laptop 12 Fastener Guide
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
77
All Time:
551
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Did you lose a screw in your Framework Laptop 12? Fear not! Follow this guide to replace your missing screws with the Framework Laptop 12 Fastener Kit.
The Fastener Kit only replaces the non-captive screws in your laptop.
Use the links below to jump to the part and find which screw to use:
    1. Framework Laptop 12 Fastener Guide, Fasteners information: step 1, image 1 of 2 Framework Laptop 12 Fastener Guide, Fasteners information: step 1, image 2 of 2
      • The Fastener Kit contains the following:
      • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
      • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
      • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
      • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
      • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
      • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
      • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
      Ask FixBot
    2. Framework Laptop 12 Fastener Guide, Antenna screws: step 2, image 1 of 3 Framework Laptop 12 Fastener Guide, Antenna screws: step 2, image 2 of 3 Framework Laptop 12 Fastener Guide, Antenna screws: step 2, image 3 of 3
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
      Ask FixBot
    3. Framework Laptop 12 Fastener Guide, Display screws: step 3, image 1 of 2 Framework Laptop 12 Fastener Guide, Display screws: step 3, image 2 of 2
      • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
      Ask FixBot
    4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: step 4, image 1 of 3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: step 4, image 2 of 3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: step 4, image 3 of 3
      • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
      • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
      Ask FixBot
    5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): step 5, image 1 of 3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): step 5, image 2 of 3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): step 5, image 3 of 3
      • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
      Ask FixBot
    6. Framework Laptop 12 Fastener Guide, Hinge screws (top): step 6, image 1 of 3 Framework Laptop 12 Fastener Guide, Hinge screws (top): step 6, image 2 of 3 Framework Laptop 12 Fastener Guide, Hinge screws (top): step 6, image 3 of 3
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
      Ask FixBot
    7. Framework Laptop 12 Fastener Guide, Power Button screw: step 7, image 1 of 2 Framework Laptop 12 Fastener Guide, Power Button screw: step 7, image 2 of 2
      • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
      Ask FixBot
    8. Framework Laptop 12 Fastener Guide, SSD clip screw: step 8, image 1 of 2 Framework Laptop 12 Fastener Guide, SSD clip screw: step 8, image 2 of 2
      • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
      Ask FixBot
    9. Framework Laptop 12 Fastener Guide, Touchpad screws: step 9, image 1 of 3 Framework Laptop 12 Fastener Guide, Touchpad screws: step 9, image 2 of 3 Framework Laptop 12 Fastener Guide, Touchpad screws: step 9, image 3 of 3
      • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
      • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
      Ask FixBot
    10. Framework Laptop 12 Fastener Guide, Webcam screws: step 10, image 1 of 2 Framework Laptop 12 Fastener Guide, Webcam screws: step 10, image 2 of 2
      • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
      Ask FixBot
If you need help, contact Framework support.
Arthur Shi
354,351 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 77
All Time: 551
