Framework Laptop 12 Antennas Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
79
All Time:
780
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the antennas in your Framework Laptop 12.
The Framework Laptop 12 has two antennas—one in each corner behind the top edge of the display. They connect to the wireless card via thin antenna cables, enabling both Wi-Fi and Bluetooth reception.
Removing the antennas is an extensive procedure. If you're having issues with Wi-Fi or Bluetooth reception, be sure to troubleshoot all other software and hardware possibilities before attempting this repair.
You'll encounter some component terms in this guide:
  • The Input Cover is the part that contains the keyboard and trackpad.
  • The Display Cover is the plastic bezel strip below the screen.
  • The Top Cover is the plastic shell that houses the display.
  • The Bottom Cover is the plastic shell that forms the bottom half of the laptop.
    1. Framework Laptop 12 Antennas Replacement, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Antennas Replacement, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Antennas Replacement, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Set your laptop down: step 2, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Remove the Expansion Cards: step 3, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Expansion Cards: step 3, image 2 of 2
      • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
      • The latches display a red bar when they're unlocked.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 4, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 4, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 4, image 3 of 3
      • Grip the lip of an Expansion Card with your fingers.
      • Pull the Expansion Card out of its slot and remove it.
      • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
      • Repeat this procedure to remove all remaining Expansion Cards.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Loosen the bottom screws: step 5, image 1 of 2 Framework Laptop 12 Antennas Replacement, Loosen the bottom screws: step 5, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Flip your laptop over: step 6, image 1 of 1
      • Flip your laptop face-up on your work surface.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Open your laptop: step 7, image 1 of 2 Framework Laptop 12 Antennas Replacement, Open your laptop: step 7, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement, Remove the Input Cover: step 8, image 1 of 3 Framework Laptop 12 Antennas Replacement, Remove the Input Cover: step 8, image 2 of 3 Framework Laptop 12 Antennas Replacement, Remove the Input Cover: step 8, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Loosen the battery screws: step 9, image 1 of 1
      • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Disconnect the battery: step 10, image 1 of 2 Framework Laptop 12 Antennas Replacement, Disconnect the battery: step 10, image 2 of 2
      • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
      • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Remove the battery: step 11, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the battery: step 11, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Loosen the Audio Board screw: step 12, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Remove the Audio Board: step 13, image 1 of 3 Framework Laptop 12 Antennas Replacement, Remove the Audio Board: step 13, image 2 of 3 Framework Laptop 12 Antennas Replacement, Remove the Audio Board: step 13, image 3 of 3
      • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
      • Remove the Audio Board.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Loosen the Power Button Board screw: step 14, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Remove the Power Button Board: step 15, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Power Button Board: step 15, image 2 of 2
      • Use your fingers to lift and remove the Power Button Board.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Loosen the Wi-Fi card screw: step 16, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
      • The Wi-Fi card will pop up slightly when you unfasten the bracket.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Remove the Wi-Fi card bracket: step 17, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Wi-Fi card bracket: step 17, image 2 of 2
      • Grab the Wi-Fi card bracket with your fingers and slide it off the top of the Wi-Fi card.
      • Remove the bracket and store it in a safe location for reassembly.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Disconnect the antenna cables: step 18, image 1 of 3 Framework Laptop 12 Antennas Replacement, Disconnect the antenna cables: step 18, image 2 of 3 Framework Laptop 12 Antennas Replacement, Disconnect the antenna cables: step 18, image 3 of 3
      • The Wi-Fi card has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
      • Press and hold the Wi-Fi card down with your finger.
      • Slide the flat edge of your Framework Screwdriver under the white antenna cable, as close to the metal head as possible.
      • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
      • Gently lift the connector straight up to disconnect the white antenna cable.
      • Repeat the procedure with the black antenna cable.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement, Remove the Wi-Fi card: step 19, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Wi-Fi card: step 19, image 2 of 2
      • Grab the Wi-Fi card by the edges and pull it out of its socket.
      • Remove the Wi-Fi card.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Disconnect the webcam cable: step 20, image 1 of 2 Framework Laptop 12 Antennas Replacement, Disconnect the webcam cable: step 20, image 2 of 2
      • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
      • Lift straight up to disconnect the cable.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Disconnect the display cable: step 21, image 1 of 2 Framework Laptop 12 Antennas Replacement, Disconnect the display cable: step 21, image 2 of 2
      • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Loosen the Mainboard screws: step 22, image 1 of 1
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
      • These screws are also physically marked with an orange ring on the Mainboard.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement, Remove the Mainboard: step 23, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Mainboard: step 23, image 2 of 2
      • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
      • Use your fingers to grab the Mainboard by its edges.
      • Lift and remove the Mainboard.
      Ask FixBot
    5. Framework Laptop 12 Antennas Replacement, Unthread the antenna cable: step 24, image 1 of 2 Framework Laptop 12 Antennas Replacement, Unthread the antenna cable: step 24, image 2 of 2
      • Use your fingers to lift the black plastic loop securing the antenna cable, near the heat vents by the left hinge.
      Ask FixBot
    6. Framework Laptop 12 Antennas Replacement: step 25, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 25, image 2 of 2
      • Use your fingers to lift and guide the antenna cable out of the frame channel.
      Ask FixBot
    7. Framework Laptop 12 Antennas Replacement, Unthread the webcam cable: step 26, image 1 of 2 Framework Laptop 12 Antennas Replacement, Unthread the webcam cable: step 26, image 2 of 2
      • Use your fingers to gently lift the webcam cable out of its plastic channel.
      Ask FixBot
    8. Framework Laptop 12 Antennas Replacement, Disconnect the Top Cover: step 27, image 1 of 2 Framework Laptop 12 Antennas Replacement, Disconnect the Top Cover: step 27, image 2 of 2
      • Use your Framework Screwdriver to remove the six (three per hinge) 4.5 mm‑long T5 Torx screws securing the two hinges.
      • These screws are not captive. Store them in a safe location for reassembly.
      Ask FixBot
    9. Framework Laptop 12 Antennas Replacement: step 28, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 28, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 28, image 3 of 3
      • Use your fingers to lift the hinges over the Bottom Cover lip.
      • Separate the Top Cover from the Bottom Cover.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Remove the Display Cover: step 29, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the Display Cover: step 29, image 2 of 2
      • The Display Cover is held in place with magnets along its top edge and clips along its remaining edges.
      • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 30, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 30, image 2 of 2
      • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 31, image 1 of 1
      • Remove the Display Cover.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement, Bend the hinges up: step 32, image 1 of 3 Framework Laptop 12 Antennas Replacement, Bend the hinges up: step 32, image 2 of 3 Framework Laptop 12 Antennas Replacement, Bend the hinges up: step 32, image 3 of 3
      • Use your fingers to twist the right hinge plate until it's flipped on top of the display.
      • The stiff hinge can be difficult to twist. Wear some work gloves, or use a cloth to help get a better grip.
      Ask FixBot
    5. Framework Laptop 12 Antennas Replacement: step 33, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 33, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 33, image 3 of 3
      • Twist the left hinge plate until it's flipped on top of the display.
      Ask FixBot
    6. Framework Laptop 12 Antennas Replacement, Release the cables from the hinges: step 34, image 1 of 2 Framework Laptop 12 Antennas Replacement, Release the cables from the hinges: step 34, image 2 of 2
      • Use your fingers to grab the two cables coming out of the left hinge.
      • Pull gently to pop out the black cable clip and release the cables.
      • Store the cable clip for reassembly.
      Ask FixBot
    7. Framework Laptop 12 Antennas Replacement: step 35, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 35, image 2 of 2
      • Repeat the procedure on the right hinge to release the cables.
      Ask FixBot
    8. Framework Laptop 12 Antennas Replacement, Twist the hinge plates down: step 36, image 1 of 3 Framework Laptop 12 Antennas Replacement, Twist the hinge plates down: step 36, image 2 of 3 Framework Laptop 12 Antennas Replacement, Twist the hinge plates down: step 36, image 3 of 3
      • Use your fingers to twist both hinge plates back down so they lay flat on your work surface.
      Ask FixBot
    9. Framework Laptop 12 Antennas Replacement, Remove the display screws: step 37, image 1 of 1
      • Use your Framework Screwdriver to remove the four 3.3 mm‑long T5 Torx screws securing the display to the Top Cover.
      Ask FixBot
    10. Framework Laptop 12 Antennas Replacement, Slide the display down: step 38, image 1 of 2 Framework Laptop 12 Antennas Replacement, Slide the display down: step 38, image 2 of 2
      • Use your fingers to hold the bottom edge of the Top Cover in place.
      • Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
      • Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
      Ask FixBot
    11. Framework Laptop 12 Antennas Replacement, Lift the display: step 39, image 1 of 2 Framework Laptop 12 Antennas Replacement, Lift the display: step 39, image 2 of 2
      • Use your fingers to lift the top edge of the display from the Top Cover.
      Ask FixBot
    12. Framework Laptop 12 Antennas Replacement, Remove the display: step 40, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the display: step 40, image 2 of 2
      • Lift and remove the display from the Top Cover.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Remove the antenna screws: step 41, image 1 of 2 Framework Laptop 12 Antennas Replacement, Remove the antenna screws: step 41, image 2 of 2
      • Use your Framework Screwdriver to remove the two (one per antenna) 2.5 mm‑long T5 Torx screws securing the antennas to the Top Cover.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Unthread the antenna cables: step 42, image 1 of 2 Framework Laptop 12 Antennas Replacement, Unthread the antenna cables: step 42, image 2 of 2
      • Use your fingers to lift the right antenna away from the Top Cover.
      • Carefully guide the white antenna cable out of its channel.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 43, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 43, image 2 of 2
      • Use your fingers to lift the left antenna away from the Top Cover.
      • Carefully guide the black antenna cable out of its channel.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement, Remove the antennas: step 44, image 1 of 1
      • Remove the antennas.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Disassembly complete: step 45, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the antennas: step 46, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the antennas: step 46, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the antennas: step 46, image 3 of 3
      • To install the antennas, you'll fasten them onto the frame first, then route each antenna cable into its Top Cover channel.
      • Lay each antenna in place in the Top Cover.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 47, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 47, image 2 of 2
      • Use your Framework Screwdriver to install the two (one per antenna) 2.5 mm‑long T5 Torx screws to secure the antennas to the Top Cover.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 48, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 48, image 2 of 2
      • Use your fingers and your Framework Screwdriver to carefully guide each antenna cable back into its channel.
      • Zoom in on the second photo to see how the antenna cables sit in their channels.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the display: step 49, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the display: step 49, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the display: step 49, image 3 of 3
      • Lay the display in place in the Top Cover, such that the top edge of the display is slightly below the top edge of the Top Cover.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 50, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 50, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 50, image 3 of 3
      • Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
      • The top edge shouldn't have any gaps when the display's in place.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Install the display screws: step 51, image 1 of 1
      • Use your Framework Screwdriver to install the four 3.3 mm‑long T5 Torx screws to secure the display to the Top Cover.
      • Make sure you don't accidentally install the 4.5 mm‑long hinge screws here. They look identical, but the hinge screws are longer.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may damage the screw tabs.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement: step 52, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 52, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 52, image 3 of 3
      • Use your fingers to twist both hinge plates so they're flipped over the display.
      Ask FixBot
    5. Framework Laptop 12 Antennas Replacement: step 53, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 53, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 53, image 3 of 3
      • Place the cable clip around the right hinge cables, where they were bent from being inserted into the hinge.
      • Use your fingers to press the clip into the hinge to secure the cables.
      Ask FixBot
    6. Framework Laptop 12 Antennas Replacement: step 54, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 54, image 2 of 2
      • Repeat the procedure on the left hinge to secure the left cables.
      Ask FixBot
    7. Framework Laptop 12 Antennas Replacement: step 55, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 55, image 2 of 2
      • Make sure both cable clips are fully inserted into the hinges, so that they won't be snagged when the hinges pivot.
      Ask FixBot
    8. Framework Laptop 12 Antennas Replacement: step 56, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 56, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 56, image 3 of 3
      • Use your fingers to twist both hinge plates so that they lay flat on your work surface.
      Ask FixBot
    9. Framework Laptop 12 Antennas Replacement: step 57, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 57, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 57, image 3 of 3
      • Lay the Display Cover in place below the display.
      • Use your finger to press along the length of the Display Cover to snap it onto the laptop.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Reconnect the Top Cover: step 58, image 1 of 3 Framework Laptop 12 Antennas Replacement, Reconnect the Top Cover: step 58, image 2 of 3 Framework Laptop 12 Antennas Replacement, Reconnect the Top Cover: step 58, image 3 of 3
      • Use your fingers to lift the Top Cover hinges over the Bottom Cover lip.
      • Lay the hinges in place in the Bottom Cover.
      • Use the plastic alignment pins to align each hinge in place.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 59, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 59, image 2 of 2
      • Use your Framework Screwdriver to install the six 4.5 mm‑long T5 Torx screws securing the two hinges.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 60, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 60, image 2 of 2
      • Use your fingers to gently press the webcam cable into its plastic channel.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement: step 61, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 61, image 2 of 2
      • Use your fingers and your Framework Screwdriver to carefully press and guide the black antenna cable back into its channel.
      • Zoom in on the second image to see how the antenna cable sits in its channel.
      Ask FixBot
    5. Framework Laptop 12 Antennas Replacement: step 62, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 62, image 2 of 2
      • Press the black loop over the antenna cable and onto the Bottom Cover. If it doesn't stick, use a bit of thin double-sided tape to hold it down.
      Ask FixBot
    6. Framework Laptop 12 Antennas Replacement, Install the Mainboard: step 63, image 1 of 2 Framework Laptop 12 Antennas Replacement, Install the Mainboard: step 63, image 2 of 2
      • Carefully lay the Mainboard in the laptop.
      • Use the two alignment pins to help align the Mainboard to the laptop.
      • Be careful not to trap the webcam, display, and antenna cables under the Mainboard as you set it in place.
      Ask FixBot
    7. Framework Laptop 12 Antennas Replacement: step 64, image 1 of 1
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
      Ask FixBot
    8. Framework Laptop 12 Antennas Replacement: step 65, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 65, image 2 of 2
      • Align and press the display cable straight down onto its connector.
      Ask FixBot
    9. Framework Laptop 12 Antennas Replacement: step 66, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 66, image 2 of 2
      • Align and press the webcam cable straight down onto its connector.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the Wi-Fi card: step 67, image 1 of 2 Framework Laptop 12 Antennas Replacement, Install the Wi-Fi card: step 67, image 2 of 2
      • Hold the Wi-Fi card by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi card's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi card into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi card fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 68, image 1 of 3 Framework Laptop 12 Antennas Replacement: step 68, image 2 of 3 Framework Laptop 12 Antennas Replacement: step 68, image 3 of 3
      • Hold the Wi-Fi card down with your finger.
      • Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 69, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 69, image 2 of 2
      • Slide the Wi-Fi bracket over the top edge of the Wi-Fi card.
      Ask FixBot
    4. Framework Laptop 12 Antennas Replacement: step 70, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the Power Button Board: step 71, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the Power Button Board: step 71, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the Power Button Board: step 71, image 3 of 3
      • Use your fingers to lay the Power Button Board in place.
      • Use the two plastic pins on the laptop to align the Power Button Board.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 72, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Power Button Board.
      • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the Audio Board: step 73, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the Audio Board: step 73, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the Audio Board: step 73, image 3 of 3
      • Insert the Audio Board into the laptop at an angle to help align the headphone jack.
      • Use the two plastic alignment pins on the laptop to help with final alignment.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 74, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Audio Board.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the battery: step 75, image 1 of 1
      • Lay the battery in its recess in the laptop.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 76, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 76, image 2 of 2
      • Use your finger to push the battery down near its connector to reconnect it.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement: step 77, image 1 of 1
      • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the Input Cover: step 78, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the Input Cover: step 78, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the Input Cover: step 78, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement: step 79, image 1 of 2 Framework Laptop 12 Antennas Replacement: step 79, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Antennas Replacement, Tighten the bottom screws: step 80, image 1 of 2 Framework Laptop 12 Antennas Replacement, Tighten the bottom screws: step 80, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      Ask FixBot
    1. Framework Laptop 12 Antennas Replacement, Install the Expansion Cards: step 81, image 1 of 3 Framework Laptop 12 Antennas Replacement, Install the Expansion Cards: step 81, image 2 of 3 Framework Laptop 12 Antennas Replacement, Install the Expansion Cards: step 81, image 3 of 3
      • Slide each Expansion Card into its Expansion Card slot.
      Ask FixBot
    2. Framework Laptop 12 Antennas Replacement, Lock the Expansion Card slots: step 82, image 1 of 2 Framework Laptop 12 Antennas Replacement, Lock the Expansion Card slots: step 82, image 2 of 2
      • If there's a red bar showing under either Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
351,823 Reputation
937 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,142 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 79
All Time: 780
