Up to 20% off select tools
Framework Desktop Power Supply Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
131
All Time:
2,176
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the power supply in your Framework Desktop.
    1. Framework Desktop Power Supply Replacement, Power down your Desktop: step 1, image 1 of 2 Framework Desktop Power Supply Replacement, Power down your Desktop: step 1, image 2 of 2
      • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
      • Wait one minute before continuing to allow your Desktop to fully power down.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Remove the Handle: step 2, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Handle: step 2, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Handle: step 2, image 3 of 3
      • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
      • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
      • Remove the Handle.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Remove the Top Panel screws: step 3, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Top Panel screws: step 3, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Top Panel screws: step 3, image 3 of 3
      • Use your finger to lift up the two D-rings on the Top Panel screws.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement: step 4, image 1 of 3 Framework Desktop Power Supply Replacement: step 4, image 2 of 3 Framework Desktop Power Supply Replacement: step 4, image 3 of 3
      • Use your fingers to twist the screw counter-clockwise and loosen it.
      • Remove the Top Panel screw.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement: step 5, image 1 of 3 Framework Desktop Power Supply Replacement: step 5, image 2 of 3 Framework Desktop Power Supply Replacement: step 5, image 3 of 3
      • Repeat the same procedure for the other Top Panel screw.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Remove the Top Panel: step 6, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Top Panel: step 6, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Top Panel: step 6, image 3 of 3
      • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
      • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
      • Lift the Top Panel off the chassis and remove it.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Remove the Left Panel: step 7, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Left Panel: step 7, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Left Panel: step 7, image 3 of 3
      • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
      • Remove the Left Panel.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Lay down the Desktop: step 8, image 1 of 2 Framework Desktop Power Supply Replacement, Lay down the Desktop: step 8, image 2 of 2
      • Lay down the Desktop on its side so the fan is facing upward.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Disconnect the fan: step 9, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the fan: step 9, image 2 of 2
      • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement: step 10, image 1 of 2 Framework Desktop Power Supply Replacement: step 10, image 2 of 2
      • If you aren't using an RGB fan, then skip this step.
      • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Remove the CPU fan screws: step 11, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the CPU fan screws: step 11, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Remove the fan duct: step 12, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the fan duct: step 12, image 2 of 2
      • Lift the fan duct off the fan and remove it.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement, Remove the fan: step 13, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the fan: step 13, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the fan: step 13, image 3 of 3
      • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Disconnect the top Expansion Card cable: step 14, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the top Expansion Card cable: step 14, image 2 of 2
      • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Disconnect the main power cable: step 15, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the main power cable: step 15, image 2 of 2
      • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Disconnect the CPU power cable: step 16, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the CPU power cable: step 16, image 2 of 2
      • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Disconnect the bottom Expansion Card cable: step 17, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the bottom Expansion Card cable: step 17, image 2 of 2
      • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Reposition the Desktop: step 18, image 1 of 2 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 18, image 2 of 2
      • Lift the Desktop so it stands upright on your work surface.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement, Remove the Right Panel: step 19, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Right Panel: step 19, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Right Panel: step 19, image 3 of 3
      • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
      • Remove the Right Panel.
      Ask FixBot
    7. Framework Desktop Power Supply Replacement, Remove the top plate screws: step 20, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the top plate screws: step 20, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the top plate screws: step 20, image 3 of 3
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
      Ask FixBot
    8. Framework Desktop Power Supply Replacement, Remove the top plate: step 21, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the top plate: step 21, image 2 of 2
      • Lift the top plate off the Desktop and remove it.
      Ask FixBot
    9. Framework Desktop Power Supply Replacement, Reposition the Desktop: step 22, image 1 of 2 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 22, image 2 of 2
      • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
      Ask FixBot
    10. Framework Desktop Power Supply Replacement, Remove the Wi-Fi Module screw: step 23, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the Wi-Fi Module screw: step 23, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
      Ask FixBot
    11. Framework Desktop Power Supply Replacement, Disconnect the Wi-Fi module: step 24, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the Wi-Fi module: step 24, image 2 of 2
      • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
      Ask FixBot
    12. Framework Desktop Power Supply Replacement, Reposition the Wi-Fi module: step 25, image 1 of 3 Framework Desktop Power Supply Replacement, Reposition the Wi-Fi module: step 25, image 2 of 3 Framework Desktop Power Supply Replacement, Reposition the Wi-Fi module: step 25, image 3 of 3
      • Move the Wi-Fi module towards the center of the Mainboard to keep it out of the way.
      Ask FixBot
    13. Framework Desktop Power Supply Replacement, Reposition the Desktop: step 26, image 1 of 3 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 26, image 2 of 3 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 26, image 3 of 3
      • Rotate the Desktop onto its right side so the Mainboard is facing upward.
      Ask FixBot
    14. Framework Desktop Power Supply Replacement, Disconnect the power button: step 27, image 1 of 2 Framework Desktop Power Supply Replacement, Disconnect the power button: step 27, image 2 of 2
      • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
      Ask FixBot
    15. Framework Desktop Power Supply Replacement, Remove the Mainboard screws: step 28, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the Mainboard screws: step 28, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
      Ask FixBot
    16. Framework Desktop Power Supply Replacement, Remove the Mainboard: step 29, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the Mainboard: step 29, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the Mainboard: step 29, image 3 of 3
      • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
      • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Remove the rear plate screws: step 30, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the rear plate screws: step 30, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the rear plate screws: step 30, image 3 of 3
      • Use your Framework Desktop Screwdriver to remove the three 5.9 mm‑long Phillips screws securing the power supply.
      • Optionally, you can remove the six 4.0 mm‑long screws securing the rear plate to make removing the power supply easier.
      • If you don't remove the rear plate screws, skip the next step.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Remove the rear plate: step 31, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the rear plate: step 31, image 2 of 2
      • Pull the rear plate off the back of the Desktop and remove it.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Remove the power supply screw: step 32, image 1 of 2 Framework Desktop Power Supply Replacement, Remove the power supply screw: step 32, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the 4.0 mm‑long Phillips screw securing the power supply.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Reposition the power supply: step 33, image 1 of 3 Framework Desktop Power Supply Replacement, Reposition the power supply: step 33, image 2 of 3 Framework Desktop Power Supply Replacement, Reposition the power supply: step 33, image 3 of 3
      • Lift the power supply out of its slot and let it rest on the left side of the Desktop.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Remove the power supply: step 34, image 1 of 3 Framework Desktop Power Supply Replacement, Remove the power supply: step 34, image 2 of 3 Framework Desktop Power Supply Replacement, Remove the power supply: step 34, image 3 of 3
      • Push the right Expansion Card cable through the gap between the power supply and its duct.
      • The gap is very small and might require some force to thread the cable through.
      • Remove the power supply.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Disassembly complete: step 35, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Place the mounting bracket: step 36, image 1 of 2 Framework Desktop Power Supply Replacement, Place the mounting bracket: step 36, image 2 of 2
      • If your power supply doesn't come with its mounting bracket and Power Supply Duct pre-installed, follow the next four steps. Otherwise, skip ahead four steps.
      • Place the mounting bracket on the corner of the power supply closest to the wire bundle.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Install the mounting bracket screw: step 37, image 1 of 2 Framework Desktop Power Supply Replacement, Install the mounting bracket screw: step 37, image 2 of 2
      • Use your Framework Desktop Screwdriver to Install the 5.8 mm‑long Phillips screw securing the mounting bracket.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Place the Power Supply Duct: step 38, image 1 of 2 Framework Desktop Power Supply Replacement, Place the Power Supply Duct: step 38, image 2 of 2
      • Place the Power Supply Duct on the power supply and align its screw holes.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Install the Power Supply Duct screws: step 39, image 1 of 2 Framework Desktop Power Supply Replacement, Install the Power Supply Duct screws: step 39, image 2 of 2
      • Use your Framework Desktop Screwdriver to Install the three 5.8 mm‑long Phillips screws securing the Power Supply Duct.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Insert the Expansion card cable: step 40, image 1 of 3 Framework Desktop Power Supply Replacement, Insert the Expansion card cable: step 40, image 2 of 3 Framework Desktop Power Supply Replacement, Insert the Expansion card cable: step 40, image 3 of 3
      • Thread the right Expansion card cable through the gap between the power supply and its duct.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement, Place the power supply: step 41, image 1 of 2 Framework Desktop Power Supply Replacement, Place the power supply: step 41, image 2 of 2
      • Place the power supply into its slot in the bottom of the Desktop.
      Ask FixBot
    7. Framework Desktop Power Supply Replacement, Install the power supply screw: step 42, image 1 of 2 Framework Desktop Power Supply Replacement, Install the power supply screw: step 42, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the 4.0 mm‑long Phillips screw securing the power supply.
      Ask FixBot
    8. Framework Desktop Power Supply Replacement, Place the rear plate: step 43, image 1 of 2 Framework Desktop Power Supply Replacement, Place the rear plate: step 43, image 2 of 2
      • Place the rear plate onto the back of the Desktop.
      Ask FixBot
    9. Framework Desktop Power Supply Replacement, Install the rear plate screws: step 44, image 1 of 3 Framework Desktop Power Supply Replacement, Install the rear plate screws: step 44, image 2 of 3 Framework Desktop Power Supply Replacement, Install the rear plate screws: step 44, image 3 of 3
      • Use your Framework Desktop Screwdriver to install the three 5.9 mm‑long Phillips screws securing the power supply.
      • If you removed the rear plate, install the six 4.0 mm‑long screws securing the rear plate.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Place the Mainboard: step 45, image 1 of 3 Framework Desktop Power Supply Replacement, Place the Mainboard: step 45, image 2 of 3 Framework Desktop Power Supply Replacement, Place the Mainboard: step 45, image 3 of 3
      • Grab the Mainboard by its heatsink and slide it into the chassis.
      • Align the rear ports with its cutout and the screw posts with the screw holes on the Mainboard.
      • You'll feel the Mainboard rest onto the screw posts when it's aligned properly.
      • Make sure no cables are trapped underneath the Mainboard before continuing.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement, Install the Mainboard screws: step 46, image 1 of 2 Framework Desktop Power Supply Replacement, Install the Mainboard screws: step 46, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the four 8.2 mm‑long Phillips screws securing the Mainboard.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Connect the power button: step 47, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the power button: step 47, image 2 of 2
      • Slide the power button cable over the nine-pronged connector on the Mainboard.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Reposition the Desktop: step 48, image 1 of 3 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 48, image 2 of 3 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 48, image 3 of 3
      • Rotate the Desktop onto its left side so the underside of the Mainboard is facing upward.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Install the Wi-Fi module: step 49, image 1 of 2 Framework Desktop Power Supply Replacement, Install the Wi-Fi module: step 49, image 2 of 2
      • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement, Install the Wi-Fi module screw: step 50, image 1 of 2 Framework Desktop Power Supply Replacement, Install the Wi-Fi module screw: step 50, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
      Ask FixBot
    7. Framework Desktop Power Supply Replacement, Reposition the Desktop: step 51, image 1 of 2 Framework Desktop Power Supply Replacement, Reposition the Desktop: step 51, image 2 of 2
      • Rotate the Desktop so it sits upright on your work surface.
      Ask FixBot
    8. Framework Desktop Power Supply Replacement, Place the top plate: step 52, image 1 of 2 Framework Desktop Power Supply Replacement, Place the top plate: step 52, image 2 of 2
      • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
      Ask FixBot
    9. Framework Desktop Power Supply Replacement: step 53, image 1 of 2 Framework Desktop Power Supply Replacement: step 53, image 2 of 2
      • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
      Ask FixBot
    10. Framework Desktop Power Supply Replacement, Install the top plate screws: step 54, image 1 of 3 Framework Desktop Power Supply Replacement, Install the top plate screws: step 54, image 2 of 3 Framework Desktop Power Supply Replacement, Install the top plate screws: step 54, image 3 of 3
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
      Ask FixBot
    11. Framework Desktop Power Supply Replacement, Install the Right Panel: step 55, image 1 of 3 Framework Desktop Power Supply Replacement, Install the Right Panel: step 55, image 2 of 3 Framework Desktop Power Supply Replacement, Install the Right Panel: step 55, image 3 of 3
      • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Right Panel and the silver base.
      • Push the Right Panel towards the base of the computer to engage the clips.
      Ask FixBot
    12. Framework Desktop Power Supply Replacement, Reposition the Mainboard: step 56, image 1 of 2 Framework Desktop Power Supply Replacement, Reposition the Mainboard: step 56, image 2 of 2
      • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
      Ask FixBot
    13. Framework Desktop Power Supply Replacement, Connect the bottom Expansion Card cable: step 57, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the bottom Expansion Card cable: step 57, image 2 of 2
      • Slide the bottom Expansion Card cable into its socket on the Mainboard.
      Ask FixBot
    14. Framework Desktop Power Supply Replacement, Connect the CPU power cable: step 58, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the CPU power cable: step 58, image 2 of 2
      • Orient the CPU power supply cable so its clip is facing the heatsink.
      • Slide the cable into its socket on the Mainboard until you feel it click into place.
      Ask FixBot
    15. Framework Desktop Power Supply Replacement, Connect the main power cable: step 59, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the main power cable: step 59, image 2 of 2
      • Orient the main power supply cable so its clip is facing away from the heatsink.
      Ask FixBot
    16. Framework Desktop Power Supply Replacement, Connect the top Expansion Card cable: step 60, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the top Expansion Card cable: step 60, image 2 of 2
      • Slide the top Expansion Card cable into its socket on the Mainboard.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Insert the fan: step 61, image 1 of 3 Framework Desktop Power Supply Replacement, Insert the fan: step 61, image 2 of 3 Framework Desktop Power Supply Replacement, Insert the fan: step 61, image 3 of 3
      • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
      • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
      • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
      • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement: step 62, image 1 of 3 Framework Desktop Power Supply Replacement: step 62, image 2 of 3 Framework Desktop Power Supply Replacement: step 62, image 3 of 3
      • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
      • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Insert the fan duct: step 63, image 1 of 2 Framework Desktop Power Supply Replacement, Insert the fan duct: step 63, image 2 of 2
      • Lay the fan duct on top of the fan with the lip facing upward.
      • Align the screw holes on the fan duct with the ones on the fan.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Install the fan screws: step 64, image 1 of 2 Framework Desktop Power Supply Replacement, Install the fan screws: step 64, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement, Connect the fan: step 65, image 1 of 2 Framework Desktop Power Supply Replacement, Connect the fan: step 65, image 2 of 2
      • Orient the main fan cable so its two vertical lines are facing you.
      • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement, Connect the RGB cable: step 66, image 1 of 3 Framework Desktop Power Supply Replacement, Connect the RGB cable: step 66, image 2 of 3 Framework Desktop Power Supply Replacement, Connect the RGB cable: step 66, image 3 of 3
      • Orient the RGB cable so the arrow is on the right side of the connector.
      • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Install the Left Panel: step 67, image 1 of 3 Framework Desktop Power Supply Replacement, Install the Left Panel: step 67, image 2 of 3 Framework Desktop Power Supply Replacement, Install the Left Panel: step 67, image 3 of 3
      • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Left Panel and the silver base.
      • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
      Ask FixBot
    1. Framework Desktop Power Supply Replacement, Install the Top Panel: step 68, image 1 of 3 Framework Desktop Power Supply Replacement, Install the Top Panel: step 68, image 2 of 3 Framework Desktop Power Supply Replacement, Install the Top Panel: step 68, image 3 of 3
      • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
      • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
      • There should be a small gap between the Top Panel and the front of the Desktop.
      • Lay the Top Panel flat on the chassis to align the remaining clips.
      Ask FixBot
    2. Framework Desktop Power Supply Replacement: step 69, image 1 of 2 Framework Desktop Power Supply Replacement: step 69, image 2 of 2
      • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
      Ask FixBot
    3. Framework Desktop Power Supply Replacement, Install the Handle: step 70, image 1 of 2 Framework Desktop Power Supply Replacement, Install the Handle: step 70, image 2 of 2
      • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
      • Place the Handle over the Top Panel screw holes.
      • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
      Ask FixBot
    4. Framework Desktop Power Supply Replacement, Install the top panel screws: step 71, image 1 of 3 Framework Desktop Power Supply Replacement, Install the top panel screws: step 71, image 2 of 3 Framework Desktop Power Supply Replacement, Install the top panel screws: step 71, image 3 of 3
      • Insert the top panel screw into its hole and twist clockwise until it feels snug.
      Ask FixBot
    5. Framework Desktop Power Supply Replacement: step 72, image 1 of 3 Framework Desktop Power Supply Replacement: step 72, image 2 of 3 Framework Desktop Power Supply Replacement: step 72, image 3 of 3
      • Repeat the same procedure for the other top panel screw.
      Ask FixBot
    6. Framework Desktop Power Supply Replacement: step 73, image 1 of 3 Framework Desktop Power Supply Replacement: step 73, image 2 of 3 Framework Desktop Power Supply Replacement: step 73, image 3 of 3
      • Use your finger to close the two D-rings on the top panel screws.
      Ask FixBot
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
253,252 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 131
All Time: 2,176
