Up to 20% off select tools
Framework Desktop Power Button Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
97
All Time:
858
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the Power Button Board in your Framework Desktop.
    1. Framework Desktop Power Button Board Replacement, Power down your Desktop: step 1, image 1 of 3 Framework Desktop Power Button Board Replacement, Power down your Desktop: step 1, image 2 of 3 Framework Desktop Power Button Board Replacement, Power down your Desktop: step 1, image 3 of 3
      • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
      • Wait one minute before continuing to allow your Desktop to fully power down.
      • Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Remove the Left Panel: step 2, image 1 of 3 Framework Desktop Power Button Board Replacement, Remove the Left Panel: step 2, image 2 of 3 Framework Desktop Power Button Board Replacement, Remove the Left Panel: step 2, image 3 of 3
      • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
      • Remove the Left Panel.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Remove the Right Panel: step 3, image 1 of 3 Framework Desktop Power Button Board Replacement, Remove the Right Panel: step 3, image 2 of 3 Framework Desktop Power Button Board Replacement, Remove the Right Panel: step 3, image 3 of 3
      • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
      • Remove the Right Panel.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Remove the Front Panel: step 4, image 1 of 3 Framework Desktop Power Button Board Replacement, Remove the Front Panel: step 4, image 2 of 3 Framework Desktop Power Button Board Replacement, Remove the Front Panel: step 4, image 3 of 3
      • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
      Ask FixBot
    2. Framework Desktop Power Button Board Replacement, Remove the top plate screws: step 5, image 1 of 2 Framework Desktop Power Button Board Replacement, Remove the top plate screws: step 5, image 2 of 2
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
      Ask FixBot
    3. Framework Desktop Power Button Board Replacement, Remove the top plate: step 6, image 1 of 2 Framework Desktop Power Button Board Replacement, Remove the top plate: step 6, image 2 of 2
      • Lift the top plate off the Desktop and remove it.
      Ask FixBot
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 7, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 7, image 2 of 2
      • Rotate the Desktop onto its right side so the Mainboard is facing upward.
      Ask FixBot
    5. Framework Desktop Power Button Board Replacement, Disconnect the power button: step 8, image 1 of 2 Framework Desktop Power Button Board Replacement, Disconnect the power button: step 8, image 2 of 2
      • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
      Ask FixBot
    6. Framework Desktop Power Button Board Replacement, Reroute the power button cable: step 9, image 1 of 2 Framework Desktop Power Button Board Replacement, Reroute the power button cable: step 9, image 2 of 2
      • Pull the power button cable out of its rubber clips in the chassis.
      Ask FixBot
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 10, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 10, image 2 of 2
      • Rotate the Desktop so it sits upright.
      Ask FixBot
    8. Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: step 11, image 1 of 2 Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: step 11, image 2 of 2
      • Use your Framework Desktop Screwdriver to remove the two 4.5 mm‑long screws securing the Power Button Board.
      Ask FixBot
    9. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: step 12, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: step 12, image 2 of 2
      • Use your finger to pull the Power Button Board off its alignment peg.
      Ask FixBot
    10. Framework Desktop Power Button Board Replacement, Remove the Power Button Board: step 13, image 1 of 3 Framework Desktop Power Button Board Replacement, Remove the Power Button Board: step 13, image 2 of 3 Framework Desktop Power Button Board Replacement, Remove the Power Button Board: step 13, image 3 of 3
      • Pull the Power Button Board away from the Desktop, threading its cable through the chassis.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Disassembly complete: step 14, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Place the Power Button Board: step 15, image 1 of 3 Framework Desktop Power Button Board Replacement, Place the Power Button Board: step 15, image 2 of 3 Framework Desktop Power Button Board Replacement, Place the Power Button Board: step 15, image 3 of 3
      • Insert the Power Button Board cable into the slot in the Desktop.
      • Grip the cable from the top of the Desktop and thread it through the chassis.
      Ask FixBot
    2. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: step 16, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: step 16, image 2 of 2
      • Place the board into its slot in the Desktop so the alignment peg is threaded through its hole in the board.
      Ask FixBot
    3. Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: step 17, image 1 of 2 Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: step 17, image 2 of 2
      • Use your Framework Desktop Screwdriver to install the two 4.5 mm‑long screws securing the Power Button Board.
      Ask FixBot
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 18, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 18, image 2 of 2
      Ask FixBot
    5. Framework Desktop Power Button Board Replacement, Reroute the power button cable: step 19, image 1 of 2 Framework Desktop Power Button Board Replacement, Reroute the power button cable: step 19, image 2 of 2
      • Press the power button cable into its rubber clips in the chassis.
      Ask FixBot
    6. Framework Desktop Power Button Board Replacement, Connect the power button: step 20, image 1 of 2 Framework Desktop Power Button Board Replacement, Connect the power button: step 20, image 2 of 2
      • Slide the power button cable over the nine-pronged connector on the Mainboard.
      Ask FixBot
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 21, image 1 of 2 Framework Desktop Power Button Board Replacement, Reposition the Desktop: step 21, image 2 of 2
      Ask FixBot
    8. Framework Desktop Power Button Board Replacement, Place the top plate: step 22, image 1 of 2 Framework Desktop Power Button Board Replacement, Place the top plate: step 22, image 2 of 2
      • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
      Ask FixBot
    9. Framework Desktop Power Button Board Replacement: step 23, image 1 of 2 Framework Desktop Power Button Board Replacement: step 23, image 2 of 2
      • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
      Ask FixBot
    10. Framework Desktop Power Button Board Replacement, Install the top plate screws: step 24, image 1 of 2 Framework Desktop Power Button Board Replacement, Install the top plate screws: step 24, image 2 of 2
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
      Ask FixBot
    11. Framework Desktop Power Button Board Replacement, Install the Front Panel: step 25, image 1 of 3 Framework Desktop Power Button Board Replacement, Install the Front Panel: step 25, image 2 of 3 Framework Desktop Power Button Board Replacement, Install the Front Panel: step 25, image 3 of 3
      • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
      • Press the Front Panel flat to the chassis and let it align to the magnets.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Install the Right Panel: step 26, image 1 of 3 Framework Desktop Power Button Board Replacement, Install the Right Panel: step 26, image 2 of 3 Framework Desktop Power Button Board Replacement, Install the Right Panel: step 26, image 3 of 3
      • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Right Panel and the silver base.
      • Push the Right Panel towards the base of the computer to engage the clips.
      Ask FixBot
    1. Framework Desktop Power Button Board Replacement, Install the Left Panel: step 27, image 1 of 3 Framework Desktop Power Button Board Replacement, Install the Left Panel: step 27, image 2 of 3 Framework Desktop Power Button Board Replacement, Install the Left Panel: step 27, image 3 of 3
      • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Left Panel and the silver base.
      • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
      Ask FixBot
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
253,191 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 97
All Time: 858
