Up to 20% off select tools
Framework Desktop Front Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
84
All Time:
810
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Very easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the Front Panel in your Framework Desktop.
If you want to install or remove Tiles, follow this guide instead.
    1. Framework Desktop Front Panel Replacement, Remove the Front Panel: step 1, image 1 of 3 Framework Desktop Front Panel Replacement, Remove the Front Panel: step 1, image 2 of 3 Framework Desktop Front Panel Replacement, Remove the Front Panel: step 1, image 3 of 3
      • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
      Ask FixBot
    1. Framework Desktop Front Panel Replacement, Install the Front Panel: step 2, image 1 of 3 Framework Desktop Front Panel Replacement, Install the Front Panel: step 2, image 2 of 3 Framework Desktop Front Panel Replacement, Install the Front Panel: step 2, image 3 of 3
      • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
      • Press the Front Panel flat to the chassis and let it align to the magnets.
      Ask FixBot
If you need help, contact Framework support.
Author
with
Alex Diaz-Kokaisl
253,164 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 84
All Time: 810
