Up to 20% off select tools
Framework Desktop Fastener Kit
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
83
All Time:
508
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Did you lose a screw in your Framework Desktop? Fear not! Follow this guide to replace your missing screws with the Framework Desktop Fastener Kit.
    1. Framework Desktop Fastener Kit, Fastener information: step 1, image 1 of 2 Framework Desktop Fastener Kit, Fastener information: step 1, image 2 of 2
      • The Fastener Kit contains the following:
      • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
      • Two large screws labeled "M6 ring screws"
      • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
      • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
      • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
      • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
      • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
      Ask FixBot
    2. Framework Desktop Fastener Kit, Top Panel screws: step 2, image 1 of 3 Framework Desktop Fastener Kit, Top Panel screws: step 2, image 2 of 3 Framework Desktop Fastener Kit, Top Panel screws: step 2, image 3 of 3
      • The two screws labeled "M6 ring screws" secure the Top Panel.
      Ask FixBot
    3. Framework Desktop Fastener Kit, Fan screws: step 3, image 1 of 2 Framework Desktop Fastener Kit, Fan screws: step 3, image 2 of 2
      • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
      Ask FixBot
    4. Framework Desktop Fastener Kit, Mainboard screws: step 4, image 1 of 2 Framework Desktop Fastener Kit, Mainboard screws: step 4, image 2 of 2
      • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
      Ask FixBot
    5. Framework Desktop Fastener Kit, Power supply screws: step 5, image 1 of 2 Framework Desktop Fastener Kit, Power supply screws: step 5, image 2 of 2
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
      Ask FixBot
    6. Framework Desktop Fastener Kit, Top plate screws: step 6, image 1 of 3 Framework Desktop Fastener Kit, Top plate screws: step 6, image 2 of 3 Framework Desktop Fastener Kit, Top plate screws: step 6, image 3 of 3
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
      Ask FixBot
    7. Framework Desktop Fastener Kit, Rear plate screws: step 7, image 1 of 3 Framework Desktop Fastener Kit, Rear plate screws: step 7, image 2 of 3 Framework Desktop Fastener Kit, Rear plate screws: step 7, image 3 of 3
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
      Ask FixBot
    8. Framework Desktop Fastener Kit, Side power supply screw: step 8, image 1 of 2 Framework Desktop Fastener Kit, Side power supply screw: step 8, image 2 of 2
      • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
      Ask FixBot
    9. Framework Desktop Fastener Kit, Power duct screws: step 9, image 1 of 3 Framework Desktop Fastener Kit, Power duct screws: step 9, image 2 of 3 Framework Desktop Fastener Kit, Power duct screws: step 9, image 3 of 3
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
253,107 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 83
All Time: 508
