Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Framed Teardown
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
76
All Time:
529
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Framed Teardown
    1. Framed Teardown, Preparation: step 1, image 1 of 1
      • Products: Beats Headphones
      • Tools: Screwdriver, Knife
      Ask FixBot
    2. Framed Teardown, Front View of the product: step 2, image 1 of 1
      • Beats Headphone (Front view)
      Ask FixBot
    3. Framed Teardown, Disassembly of the headphone sponge part: step 3, image 1 of 1
      • Fixing method: Adhesive
      • Tear apart the adhesive section by hand
      Ask FixBot
    4. Framed Teardown, Removing the leather from the foam: step 4, image 1 of 1
      • Fastening method: Adhesive
      • Remove it by hand
      Ask FixBot
    5. Framed Teardown, Disassembly of the plastic layer: step 5, image 1 of 2 Framed Teardown, Disassembly of the plastic layer: step 5, image 2 of 2
      • Disassemble it by hand
      • If it is hard to take it off, you can use a knife cutting into the parting line to help
      Ask FixBot
    6. Framed Teardown, Disassembly of the inner sponge: step 6, image 1 of 1
      • Fixing Method: Adhesive
      Ask FixBot
    7. Framed Teardown, Disassembly of black cover: step 7, image 1 of 1
      • Peel it off by hand
      Ask FixBot
    8. Framed Teardown, Disassembly of the plastic shell: step 8, image 1 of 2 Framed Teardown, Disassembly of the plastic shell: step 8, image 2 of 2
      • Fixing method: Screw-fixed
      • After the last step, the screws appear
      • 5 screws in total
      • 2 kinds of screws
      • Rotate the screwdriver counterclockwise
      Ask FixBot
    9. Framed Teardown, Disassembly of the outer case: step 9, image 1 of 2 Framed Teardown, Disassembly of the outer case: step 9, image 2 of 2
      • Use a knife or a flathead screwdriver to cut into the parting line.
      • The casing is held together by snaps, so it may require some force to disassemble.
      Ask FixBot
    10. Framed Teardown, Disassembly of the earpiece: step 10, image 1 of 2 Framed Teardown, Disassembly of the earpiece: step 10, image 2 of 2
      • This also uses a snap-fit design. It requires more force to disassemble by hand.
      Ask FixBot
    11. Framed Teardown, Disassembly of PCB: step 11, image 1 of 3 Framed Teardown, Disassembly of PCB: step 11, image 2 of 3 Framed Teardown, Disassembly of PCB: step 11, image 3 of 3
      • 4 screws in total
      Ask FixBot
    12. Framed Teardown, Disassembly of the connecting piece: step 12, image 1 of 1
      • It is an inclined plane, so just pull it slightly to take it off
      Ask FixBot
    13. Framed Teardown, Disassembly of the rubber piece: step 13, image 1 of 1
      • Fix method: Snap structure
      • This is the last disassembly step of the left earpiece. Most of the steps for the right earpiece are the same.
      Ask FixBot
    14. Framed Teardown, Disassembly of the battery in the right earpiece: step 14, image 1 of 2 Framed Teardown, Disassembly of the battery in the right earpiece: step 14, image 2 of 2
      • Peel it off slightly by hand
      • Be careful, this battery is soft
      Ask FixBot
    15. Framed Teardown, Disassembly of the button: step 15, image 1 of 2 Framed Teardown, Disassembly of the button: step 15, image 2 of 2
      • Take it off by hand.
      • Be careful, this piece of plastic is prone to breaking.
      Ask FixBot
    16. Framed Teardown, Disassembly of the headband: step 16, image 1 of 2 Framed Teardown, Disassembly of the headband: step 16, image 2 of 2
      • Peel off the rubber part
      • The screws and the sponge then appear
      Ask FixBot
    17. Framed Teardown, Disassembly of the headband sponge: step 17, image 1 of 2 Framed Teardown, Disassembly of the headband sponge: step 17, image 2 of 2
      • The sponge is very thin, be careful not to break it
      Ask FixBot
    18. Framed Teardown, Disassembly of the plastic part of the headband: step 18, image 1 of 2 Framed Teardown, Disassembly of the plastic part of the headband: step 18, image 2 of 2
      • 2 on each side
      • 4 in total
      Ask FixBot
    19. Framed Teardown, Disassembly of the inner structure of the headband: step 19, image 1 of 2 Framed Teardown, Disassembly of the inner structure of the headband: step 19, image 2 of 2
      • Fixing method: Snap structure
      Ask FixBot
    20. Framed Teardown, Disassembly of the folding structure: step 20, image 1 of 3 Framed Teardown, Disassembly of the folding structure: step 20, image 2 of 3 Framed Teardown, Disassembly of the folding structure: step 20, image 3 of 3
      • Bend it and then push it out by hand
      Ask FixBot
    21. Framed Teardown, Disassembly of the metal piece: step 21, image 1 of 1
      • After the last step, turn it over and the metal piece will drop out
      Ask FixBot
    22. Framed Teardown, Disassembly of the metal ring: step 22, image 1 of 2 Framed Teardown, Disassembly of the metal ring: step 22, image 2 of 2
      • Use a "-" head screwdriver to help.
      Ask FixBot
    23. Framed Teardown, Display of all components: step 23, image 1 of 2 Framed Teardown, Display of all components: step 23, image 2 of 2
      • 8 categories are included
      • Sponge, Leather, Rubber, Screws, Metal, Plastic, adhesive components, electronic components
      Ask FixBot
Follow the instructions in reverse order for reassembly.
Author
with
Ryan Wang
367 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 76
All Time: 529
