Fossil Speedway Watch TI-5061 Time Setting Dial Replacement
    1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 1 of 3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 2 of 3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: step 1, image 3 of 3
      • Keep clasp in open position.
      • Push one of the spring-loaded pins out of the hole with a Push-pin.
      • Wiggle watch band and clasp till free from each other.
      Ask FixBot
    1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Back: step 2, image 1 of 1
      • Fit the blades of a pair of scissors into the grooves of the screw back.
      • Twist the screw back counter clockwise with the scissors.
      • Once the back is loose enough, you can use your fingers to twist it off.
      Ask FixBot
    1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: step 3, image 1 of 2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: step 3, image 2 of 2
      • Press the release button for the Time Setting Dial using a thin pin.
      Ask FixBot
    2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: step 4, image 1 of 2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: step 4, image 2 of 2
      • Pull the dial out gently with fingers.
      Ask FixBot
3 other people completed this guide.
Julia List
6,275 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 56
All Time: 1,963
