Fossil Speedway Watch TI-5061 Battery Replacement
  1. Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: step 1, image 1 of 3 Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: step 1, image 2 of 3 Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: step 1, image 3 of 3
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
    Ask FixBot
  2. Fossil Speedway Watch TI-5061 Battery Replacement, Back: step 2, image 1 of 1
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
    Ask FixBot
  3. Fossil Speedway Watch TI-5061 Battery Replacement, Battery: step 3, image 1 of 2 Fossil Speedway Watch TI-5061 Battery Replacement, Battery: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Place the tweezers around the battery.
    • Firmly grip the battery with the tweezers.
    • Pull the battery out and replace it with a new 371 Renata watch battery.
    Ask FixBot
5 other people completed this guide.
Caleb
376 Reputation
1 Guide authored
Cal Poly, Team 14-10, Amido Spring 2015 Member of Cal Poly, Team 14-10, Amido Spring 2015
CPSU-AMIDO-S15S14G10
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 109
All Time: 7,224
