Fossil Q Venture Gen 3 Battery Replacement
    1. Fossil Q Venture Gen 3 Battery Replacement, Battery: step 1, image 1 of 3 Fossil Q Venture Gen 3 Battery Replacement, Battery: step 1, image 2 of 3 Fossil Q Venture Gen 3 Battery Replacement, Battery: step 1, image 3 of 3
      • First, use a screwdriver to remove the band from the device.
      Ask FixBot
    2. Fossil Q Venture Gen 3 Battery Replacement: step 2, image 1 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 2, image 2 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 2, image 3 of 3
      • Once you remove the band, take a screwdriver and remove the four screws holding the backplate in place.
      Ask FixBot
    3. Fossil Q Venture Gen 3 Battery Replacement: step 3, image 1 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 3, image 2 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 3, image 3 of 3
      • The inside of the watch will be exposed. Now, you can disconnect all the golden connections (battery, display, etc) and carefully loosen the battery housing from the shell.
      Ask FixBot
    4. Fossil Q Venture Gen 3 Battery Replacement: step 4, image 1 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 4, image 2 of 3 Fossil Q Venture Gen 3 Battery Replacement: step 4, image 3 of 3
      • When the board is removed, the battery will be stuck in place with an adhesive inside the black plastic housing. Pry the battery out gently to remove it from the board.
      Ask FixBot
2 other people completed this guide.
Chris Brunston
183 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 108
All Time: 1,725
