Fossil Q Marshal Gen 2 Screen Replacement
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
    Ask FixBot
  2. Fossil Q Marshal Gen 2 Screen Replacement: step 2, image 1 of 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
    Ask FixBot
  3. Fossil Q Marshal Gen 2 Screen Replacement: step 3, image 1 of 2 Fossil Q Marshal Gen 2 Screen Replacement: step 3, image 2 of 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
    Ask FixBot
  4. Fossil Q Marshal Gen 2 Screen Replacement: step 4, image 1 of 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
    Ask FixBot
  5. Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 1 of 3 Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 2 of 3 Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 3 of 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
    Ask FixBot
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: step 6, image 1 of 2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: step 6, image 2 of 2
    • The screen can now be removed out of the front-side of the watch.
    Ask FixBot
13 other people completed this guide.
Matthew Tucker
586 Reputation
3 Guides authored
IUPUI, Team S2-G5, Harley Fall 2017 Member of IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Members
6 Guides authored
18 Guide Comments
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - Reply Share
Where can I buy replacement screen for gen 1
David Aslamazashvili - Reply Share
Is the screen glued to the bezel of the watch?
Jose - Reply Share
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - Reply Share
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 58
All Time: 20,118
