Fossil Q Marshal Gen 2 Disassembly
Views: 15K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
105
All Time:
14,694
Comments: 4
4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows the general disassembly of the watch. This guide serves as a prerequisite for all guides on internal component replacement . When following this guide be extra careful when undoing wire connections because they can be fragile.
Tools
  • Spudger
    4.9
  • Tweezers
    1. Fossil Q Marshal Gen 2 Disassembly, Back Cover: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
      • Remove chain from opposing side of watch body.
      Ask FixBot
    2. Fossil Q Marshal Gen 2 Disassembly: step 2, image 1 of 1
      • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
      • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
      Ask FixBot
    3. Fossil Q Marshal Gen 2 Disassembly: step 3, image 1 of 2 Fossil Q Marshal Gen 2 Disassembly: step 3, image 2 of 2
      • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
      • Utilize a spudger to pull the orange connector off of the motherboard.
      Ask FixBot
    4. Fossil Q Marshal Gen 2 Disassembly: step 4, image 1 of 1
      • Utilize tweezers to pull the white battery connector from the motherboard.
      Ask FixBot
    5. Fossil Q Marshal Gen 2 Disassembly: step 5, image 1 of 3 Fossil Q Marshal Gen 2 Disassembly: step 5, image 2 of 3 Fossil Q Marshal Gen 2 Disassembly: step 5, image 3 of 3
      • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
      • Taking the flat end of the spudger, pry it up.
      Ask FixBot
5 other people completed this guide.
Matthew Tucker
586 Reputation
3 Guides authored
IUPUI, Team S2-G5, Harley Fall 2017 Member of IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Members
48 Guides authored
4 Guide Comments
How do you remove the power switch?
Rahim Parpia - Reply Share
So when i go to reverse the process. It feels like I connect the top screen and top pieces back in and it won't turn on. Any reason why. Sometimes it vibrates them dnt come up.
Justin Huron - Reply Share
Thanks, i droped my Fossil Q Founder 2.0 (FTW2119) and this guide help me fix it, i recomend put in the name that also works with mine.
Abílio Páscoa - Reply Share
Which battery do I need for this watch. I need a replacement.
Pamela Asamoah - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 105
All Time: 14,694
