Fossil Q Marshal Gen 2 Battery Replacement
  1. Fossil Q Marshal Gen 2 Battery Replacement, Back Cover: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
    Ask FixBot
  2. Fossil Q Marshal Gen 2 Battery Replacement: step 2, image 1 of 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
    Ask FixBot
  3. Fossil Q Marshal Gen 2 Battery Replacement: step 3, image 1 of 2 Fossil Q Marshal Gen 2 Battery Replacement: step 3, image 2 of 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
    Ask FixBot
  4. Fossil Q Marshal Gen 2 Battery Replacement: step 4, image 1 of 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
    Ask FixBot
  5. Fossil Q Marshal Gen 2 Battery Replacement: step 5, image 1 of 3 Fossil Q Marshal Gen 2 Battery Replacement: step 5, image 2 of 3 Fossil Q Marshal Gen 2 Battery Replacement: step 5, image 3 of 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
    Ask FixBot
  6. Fossil Q Marshal Gen 2 Battery Replacement, Battery: step 6, image 1 of 1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
    Ask FixBot
  7. Fossil Q Marshal Gen 2 Battery Replacement: step 7, image 1 of 2 Fossil Q Marshal Gen 2 Battery Replacement: step 7, image 2 of 2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
    Ask FixBot
16 other people completed this guide.
Clay Walker
767 Reputation
1 Guide authored
IUPUI, Team S2-G5, Harley Fall 2017 Member of IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Members
6 Guides authored
13 Guide Comments
I have read your awesome guide. This is really helpful.
https://powerbank-online.com/reviews/bat...
Ellen Sam - Reply Share
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
Rafael “Satriabhi” Atheya - Reply Share
model battery?
oleksiyuk - Reply Share
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
dustykeith17 - Reply Share
Help! I can’t find a replacement battery.
Pedro Pimentel - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 140
All Time: 46,575
